本设计的内容为淮阴工学院建筑工程教学楼,设计内容主要分为两大部分:第一为建筑方案设计;第二为结构方案设计。建筑设计要求建筑物造型美观、新颖,满足各项使用功能要求,功能区组合合理。该教学楼主体为五层框架结构,在确定框架布局之后,需进行了层间荷载代表值的计算,然后用顶点位移法算出自震周期,按底部剪力法计算出水平地震荷载作用大小,求出在水平荷载作用下结构的内力(弯矩、剪力、轴力)。然后计算竖向荷载(恒载及活荷载)作用下结构的内力,最终找出最不利的一组或几组内力组合。根据最安全的结果计算配筋并绘图。另外还进行了结构方案中的室内楼梯的设计,完成了平台板,梯段板,平台梁,斜梁等构件的内力和配筋计算以及施工图绘制,同时选取部分梁、板、柱进行了构件的内力和配筋计算。在整个结构的设计过程中,需严格遵循相关的专业规范的要求,参考相关资料和相关的最新的国家标准规范,对设计的各个环节进行综合全面的科学性考虑。
关键词 框架,结构设计,抗震设计
Contents of this design is Huaiyin Institute of Technology teaching building construction , design mainly divided into two parts : the first for the architectural design ; second for the structural design . Architectural design requirements for building beautiful shape, novel, meet the functional requirements using the Ribbon reasonable combinations. The main floor of five teaching framework , after determining the frame layout , the need for inter-layer load calculation representative value , and then calculate the vertex displacement since the earthquake cycle method , according to the base shear method to calculate the size of the horizontal seismic loads , calculated internal forces ( bending moment , shear, axial force ) structure under horizontal loads . Then calculate the internal forces under vertical loads ( dead load and live load ) the role of the structure , and ultimately identify the most unfavorable internal forces of a group or several groups of combinations . Reinforcement calculated and plotted according to the safest results. It also carried out in the interior staircase structure of the program design, complete platform boards, internal forces and reinforcement calculations and construction drawings bench boards, deck beams , oblique beams and other components , as well as selected parts of beams, plates, columns were calculation of internal forces and reinforcement components .In the design process of the entire structure , the need to strictly follow the relevant professional regulatory requirements , refer to the relevant information and the latest relevant national standards , designed to carry out all aspects of a comprehensive scientific considerations .
Keywords frame ,structural design ,seismic design
建筑面积:8681m2
建筑层数:5层
建筑高度:21m
文件内容:计算书+图纸+开题报告+任务书+实习报告
淮阴工学院建筑工程学院加固改造毕业设计.pdf
(1.1 MB, 下载次数: 1)
