框架结构是通过梁、柱组成的结构体系作为建筑的竖向承重结构,并同时承受水平荷载,它适用于多层及高度不大的高层建筑。框架结构平面布置灵活,能形成较大的空间。通过合理设计,框架结构本身的抗震性能较好,能承受较大的变形,由于框架梁柱整体现浇,进一步增强了结构的水平刚度和竖向刚度,同时提高了结构的整体工作性能,进而实现了结构的大跨度。本文通过大量的计算分析,确定框架柱的高度、截面尺寸以及框架梁的跨度和截面尺寸,使结构达到最佳承载状态,分析表明:通过合理的框架结构设计,可以有效的提高结构的竖向刚度和水平刚度,以及结构的极限承载力,并可以使结构破坏时发生塑性变形,这有利于结构内力的重分布,增加结构的延性性能,充分发挥构件的极限承载能力。
【关键词】:钢筋混凝土框架;荷载;内力组合;配筋
Frame structure's using the structure system which constitutes through a beam, pillar is an architectural Shut to accept heavy structure, and bear a level lotus to carry in the meantime, it is applicable to many layer and height not big key figures a building. The frame structure flat surface arrange vivid, can become bigger space. Pass a reasonable design, the anti-vibration of the frame structure can be better, can bear bigger transform, whole because of frame beam sprinkle now, strengthened further structural of level just degree and Shut to just degree, raised in the meantime structure of whole work function, then carried out structure of greatly across a degree. This text passes a great deal of calculation analysis and make sure frame pillar of height, cut across of noodles size and frame beam a degree and cut noodles size, make the structure attain the best loading appearance, analysis enunciation: Pass reasonable frame structure design, can effectively of exaltation structure of Shut to just degree and level just degree, and structure of extreme limit loading dint, and can make structure breakage take place Su to transform, this was advantageous to the dint in the structure of heavy distribute, increased structural ductility function, well develop the loading ability of the extreme limit of Gou piece.
Key Words: Reinforced concrete frame;The lotus carry;Inside the dint combine ;Go together with Jin
建筑面积:3091m2
建筑层数:6层
建筑高度:23.4m
毕业设计.pdf
(930.51 KB, 下载次数: 0)
