以下就是土木毕设网为大家精心整理的土木工程 毕业设计 英文参考文献50例。供大家学习。
参考文献一
[1]. Engineering - Civil Engineering; Studies from Wenzhou University Have Provided New Information about Civil Engineering (Incorporating Woodwork Fabrication into the Integrated Teaching and Learning of Civil Engineering Students)[J]. Journal of Engineering,2018,:.
[2]. Engineering - Civil Engineering; Study Findings on Civil Engineering Are Outlined in Reports from Colorado State University (Civil Engineering Workforce and Education: Twenty Years of Change)[J]. Journal of Engineering,2018,:.
[3]. Engineering - Civil Engineering; Study Results from A. Erfanian et al Provide New Insights into Civil Engineering (Analysis of bond-slip and transverse dissipative energies in confined reinforcing bars)[J]. Journal of Engineering,2018,:.
[4]. Geoinformation; Researchers from Department of Civil & Environmental Engineering Discuss Findings in Geoinformation (Improving Tree Species Classification Using UAS Multispectral Images and Texture Measures)[J]. Politics & Government Week,2018,:.
[5]. Policy and Procedural Guidance for Processing Requests To Alter US Army Corps of Engineers Civil Works Projects[J]. U.S. Department of Defense Information / FIND,2018,:.
[6]. Science - Earth Science; Findings from Department of Civil Engineering Provides New Data about Earth Science (PSHA of Van province for performance assessment using spectrally matched strong ground motion records)[J]. Science Letter,2018,:.
[7]. Genetic Programming; New Genetic Programming Study Results Reported from Department of Civil Engineering (Operational Analysis of Signalized Street Segments Using Multi-gene Genetic Programming and Functional Network Techniques)[J]. Journal of Engineering,2018,:.
[8]. CIVIL DESIGN & ENGINEERING INC., P.O. BOX 30836 FLAGSTAFF AZ 86003 USA awarded government contract[J]. Department of Energy (DOE) Documents / FIND,2018,:.
[9]. Engineering - Propulsion and Power; New Findings Reported from Cranfield University Describe Advances in Propulsion and Power (Aerodynamic Analysis of Civil Aeroengine Exhaust Systems Using Computational Fluid Dynamics)[J]. Defense & Aerospace Week,2018,:.
[10]. Engineering - Civil Engineering; Researchers from Vienna University of Technology Detail Findings in Civil Engineering (Mechanical Behavior of Prefabricated Composite Box Girders with Corrugated Steel Webs under Static Loads)[J]. Journal of Engineering,2018,:.
[11]. Beijing University of Civil Engineering and Architecture; Researchers Submit Patent Application, "Irrigation Device And System, And Method For Using The Same", for Approval (USPTO 20180235163)[J]. Politics & Government Week,2018,:.
[12]. Polymer Research; Recent Findings in Polymer Research Described by Researchers from Faculty of Civil Engineering (Flexural and web crippling properties of GFRP pultruded profiles subjected to wetting and drying cycles in different sea water conditions)[J]. Chemicals & Chemistry,2018,:.
[13]. Fluid Mechanics; Studies in the Area of Fluid Mechanics Reported from Department of Civil Engineering (Enhancing transverse mixing in streams with submerged vanes)[J]. Ecology, Environment & Conservation,2018,:.
[14]. Engineering - Civil Engineering; Researchers from Iran University of Science and Technology Discuss Findings in Civil Engineering (Impacts of turbulent flow over a channel bed with a vegetation patch on the incipient motion of sediment)[J]. Journal of Engineering,2018,:.
[15]. Technology; Researchers from School of Civil Engineering Report Recent Findings in Technology (Performance of rock-soil slope reinforcement and protection effect in cutting slope construction)[J]. Journal of Engineering,2018,:.
[16]. Engineering - Civil Engineering; Reports on Civil Engineering Findings from Shaoxing University Provide New Insights (Mechanical Behavior of Steel-HFRC Composite Girders)[J]. Journal of Engineering,2018,:.
[17]. Engineering - Civil Engineering; New Findings from North Dakota State University Describe Advances in Civil Engineering (Electrochemical Characterization of Steel Bridge Welds under Simulated Durability Test)[J]. Journal of Engineering,2018,:.
[18]. Sustainability Research; Findings from Department of Civil & Environmental Engineering Broaden Understanding of Sustainability Research (Vanillin derived from lignin liquefaction: a sustainability evaluation)[J]. Ecology, Environment & Conservation,2018,:.
[19]. Algorithms; Data on Algorithms Detailed by Researchers at School of Civil Engineering (Network Planning Method for Capacitated Metro-Based Underground Logistics System)[J]. Journal of Transportation,2018,:.
[20]. Engineering - Civil Engineering; New Civil Engineering Findings Has Been Reported by Investigators at South Dakota State University (Bridge Deterioration Quantification Protocol Using UAV)[J]. Journal of Engineering,2018,:.
[21]. Stainless Steel; Researchers from Department of Civil & Environmental Engineering Report Findings in Stainless Steel (Stainless Steel Microfibers for Strain-Sensing Smart Clay Bricks)[J]. Chemicals & Chemistry,2018,:.
[22]. Hydrology; New Hydrology Study Results from Department of Civil Engineering Described (An improved gene expression programming model for streamflow forecasting in intermittent streams)[J]. Science Letter,2018,:.
[23]. Unmanned Aircraft; Researchers at Department of Civil and Environmental Engineering Describe Findings in Unmanned Aircraft [Coordinated Sampling of Microorganisms Over Freshwater and Saltwater Environments Using an Unmanned Surface Vehicle (USV) and a Small ...][J]. Defense & Aerospace Week,2018,:.
[24]. Engineering - Civil Engineering; Research Data from Tongji University Update Understanding of Civil Engineering (Axial-Shear-Flexure Interaction Behavior of Joints in Precast Concrete Segmental Bridge Columns)[J]. Journal of Engineering,2018,:.
[25]. Engineering - Biochemical Engineering; Researchers from Department of Civil Engineering Report Findings in Biochemical Engineering (Single phase blend: An advanced microwave process for improved quality low-cost biodiesel production from kitchen food waste)[J]. Biotech Week,2018,:.
[26]. Engineering - Civil Engineering; Studies from Virginia Tech Describe New Findings in Civil Engineering (Development of a preliminary seismic risk screening tool for existing buildings in Canada)[J]. Journal of Engineering,2018,:.
参考文献二
[27]. Engineering - Civil Engineering; Findings from Texas A&M University Provide New Insights into Civil Engineering (Experimental Performance of Steel Fiber Reinforced Concrete Bridge Deck)[J]. Journal of Engineering,2018,:.
[28]. Engineering - Civil Engineering; Study Results from C. Stucki and Colleagues Broaden Understanding of Civil Engineering (Reduction of Seismic Acceleration Parameters for Temporary Bridge Design)[J]. Journal of Engineering,2018,:.
[29]. Engineering - Civil Engineering; Reports Summarize Civil Engineering Study Results from University of Windsor (Effect of aspect ratio on developing and developed narrow open channel flow with rough bed)[J]. Journal of Engineering,2018,:.
[30]. Materials Research; New Findings Reported from Department of Civil Engineering Describe Advances in Materials Research (Evaluation of Residual Compressive Strength and Behavior of Corrosion-Damaged Carbon Steel Tubular Members)[J]. Journal of Technology & Science,2018,:.
[31]. Science - Applied Clay Science; Reports Outline Applied Clay Science Study Findings from Department of Civil Engineering (Effects of drying on Atterberg limits of pyroclastic soils of Northern Turkey)[J]. Science Letter,2018,:.
[32]. Engineering - Civil Engineering; Findings from Southwest Jiaotong University in the Area of Civil Engineering Reported (Fatigue Damage Evaluation of Orthotropic Steel Deck Considering Weld Residual Stress Relaxation Based on Continuum Damage Mechanics)[J]. Journal of Engineering,2018,:.
[33]. Artificial Neural Networks; New Artificial Neural Networks Study Results from Faculty of Civil Engineering Described (Rock strength estimation: a PSO-based BP approach)[J]. Computers, Networks & Communications,2018,:.
[34]. Engineering - Safety Engineering; New Safety Engineering Findings Reported from Washington State University (Adaptive decision-making for civil infrastructure systems and communities exposed to evolving risks)[J]. Journal of Engineering,2018,:.
[35]. Engineering - Civil Engineering; Data from Hanyang University Provide New Insights into Civil Engineering (Continuum Model for Static and Dynamic Analysis of Suspension Bridges with a Floating Girder)[J]. Journal of Engineering,2018,:.
[36]. Structural Concrete; Researchers at Department of Civil Engineering Have Reported New Data on Structural Concrete (Effect of parameters on the compressive strength of fly ash based geopolymer concrete)[J]. Journal of Technology & Science,2018,:.
[37]. Engineering - Civil Engineering; Studies from L.J. Butler and Colleagues Reveal New Findings on Civil Engineering (Monitoring, Modeling, and Assessment of a Self-Sensing Railway Bridge during Construction)[J]. Journal of Engineering,2018,:.
[38]. Structural Concrete; Recent Findings in Structural Concrete Described by Researchers from Faculty of Civil Engineering (Stress-strain evaluation of steel-strapped high-strength concrete with modified self-regulating end clips)[J]. Journal of Technology & Science,2018,:.
[39]. Engineering - Civil Engineering; Studies from Castilla La Mancha University Add New Findings in the Area of Civil Engineering (Heritage Preservation Training in Civil Engineering Education: Modern Roads Restoration Projects)[J]. Journal of Engineering,2018,:.
[40]. Anions; Research Conducted at Department of Civil Engineering Has Updated Our Knowledge about Anions (Entire Process Simulation of Corrosion due to the Ingress of Chloride Ions and CO2 in Concrete)[J]. Journal of Engineering,2018,:.
[41]. Engineering - Structural Engineering; Researchers' Work from Department of Civil Engineering Focuses on Structural Engineering (Thermal post-buckling analysis of a laminated composite beam)[J]. Journal of Engineering,2018,:.
[42]. Engineering - Civil Engineering; Investigators at University of Western Ontario Discuss Findings in Civil Engineering (Analytical Approach for Seismic Performance of Extended Pile-Shafts)[J]. Journal of Engineering,2018,:.
[43]. Engineering - Civil Engineering; Findings on Civil Engineering Detailed by Investigators at University of Alberta (Fatigue life evaluation of pavement embankments made with tire derived aggregates)[J]. Journal of Engineering,2018,:.
[44]. Engineering - Civil Engineering; New Findings from University of Ottawa Update Understanding of Civil Engineering (Establishing the fundamental period of light-frame wood buildings on the basis of ambient vibration tests)[J]. Journal of Engineering,2018,:.
[45]. Engineering - Impact Engineering; Researchers from School of Civil Engineering Detail New Studies and Findings in the Area of Impact Engineering (Effect of the Lode parameter in predicting shear cracking of 2024-T351 aluminum alloy Taylor rods)[J]. Journal of Engineering,2018,:.
[46]. Environmental Research; Reports Summarize Environmental Research Findings from Department of Civil & Environmental Engineering (Evaluation of energy consumption of treating nitrate-contaminated groundwater by bioelectrochemical systems)[J]. Ecology, Environment & Conservation,2018,:.
[47]. Energy; Studies Conducted at Department of Civil Engineering on Energy Recently Reported (Phase change change humidity control material and its impact on building energy consumption)[J]. Energy Weekly News,2018,:.
[48]Peng Zhang,Song Han,Serina Ng,Xu-Hao Wang. Fiber-Reinforced Concrete with Application in Civil Engineering[J]. Advances in Civil Engineering,2018,2018:.
[49]F. Frigui,J.P. Faye,C. Martin,O. Dalverny,F. Peres,S. Judenherc. Global methodology for damage detection and localization in civil engineering structures[J]. Engineering Structures,2018,171:.
[50]. 2nd International Conference on Architecture and Civil Engineering (ICACE 2018)[J]. IOP Conference Series: Materials Science and Engineering,2018,401(1):.
