本设计分为两个部分:建筑设计、结构设计。建筑设计包括建筑方案和建筑施工图的绘制,结构设计为本设计最主要的部分。结构设计主要进行了结构方案中 轴的一代表性框架的荷载计算、内力分析及组合、构件配筋计算和抗震设计等。在确定框架布局之后,先进行竖向荷载值计算和地震、风荷载计算,然后利用 值法求出荷载作用下的结构内力(弯矩、轴力、剪力),找出最不利的一组或几组内力组合,选取最不安全的结果计算配筋并绘图,利用 建模复核计算结果。此外还进行了柱下独立基础、楼梯楼板等构件的设计。
关键词:宾馆建筑,结构设计,框架,内力计算,抗震设计,构件配筋
The design is divided into two parts: architectural design, structural design. Architectural design and construction programme of construction plans drawn, structural design-based design of the most important part. Major structural design of the structure of the programme in the AD axis framework of a representative of the load, and the combination of internal forces, component seismic reinforcement calculation and design. In determining the framework of the layout, the first for vertical load value and earthquakes, wind loads, and then using the value of D obtained under the load of internal forces (moment, the axis of shear), to identify the most adverse of a Group or several groups of internal force portfolio, select the most unsafe and reinforced the results of calculation graphics, use of PKPM modeling review the results. In addition, a separate column under the foundation, floor staircase, and other components of the design.
Key words: hotel construction, structural design, framework, internal forces calculation, seismic design, Component reinforcement
建筑面积:4380m2
建筑层数:5层
建筑高度:20.9m
计算书.pdf
(1.47 MB, 下载次数: 0)
