热门土木工程英文文献供您参考,希望能解决毕业生们的有关问题,整理好土木工程英文文献那就开始写吧!
参考文献一
[1]. Engineering - Civil Engineering; Researchers at Beijing Jiaotong University Publish New Study Findings on Civil Engineering (Numerical Analysis of the Anisotropy and Scale Effects on the Strength Characteristics of Defected Rockmass)[J]. Journal of Mathematics,2020,:.
[2]. Engineering - Civil Engineering; Study Data from Kyushu University Update Understanding of Civil Engineering (Study On Control of Wall Deflection In Earth Stepped-twin Retaining Wall Using Anchor Method By Means of Numerical Simulation)[J]. Journal of Mathematics,2020,:.
[3]. Engineering - Civil Engineering; Studies from Huazhong University of Science and Technology Reveal New Findings on Civil Engineering (Numerical Analysis of Fracture Behaviour on Marble Samples Containing Two Flaws)[J]. Journal of Mathematics,2020,:.
[4]. Engineering - Civil Engineering; Researchers from University of Tabriz Provide Details of New Studies and Findings in the Area of Civil Engineering (Optimal Design of Magnetorheological Damper Based on Tuning Bouc-Wen Model Parameters Using Hybrid Algorithms)[J]. Journal of Mathematics,2020,:.
[5]. Engineering - Civil Engineering; Researchers from Southeast University Detail Research in Civil Engineering (An IDM-Based Approach for Information Requirement in Prefabricated Construction)[J]. Information Technology Newsweekly,2020,:.
[6]. Engineering - Civil Engineering; Studies in the Area of Civil Engineering Reported from China University of Mining and Technology (Experimental Investigation of the Deformation and Failure Behavior of a Tunnel Excavated In Mixed Strata Using Transparent Soft Rock)[J]. Journal of Mathematics,2020,:.
[7]Twana Kamal Haji,Asaad Faramarzi,Nicole Metje,David Chapman,Farough Rahimzadeh. Development of an infinite element boundary to model gravity for subsurface civil engineering applications[J]. International Journal for Numerical and Analytical Methods in Geomechanics,2020,44(3):.
[8]. Engineering - Civil Engineering; Findings from Department of Civil Engineering Provides New Data about Civil Engineering (Experimental Study of Shear-Deficient RC Beam Wrapped with GFRP)[J]. Journal of Engineering,2020,:.
[9]. Engineering - Civil Engineering; Studies from Southwest Jiaotong University Have Provided New Data on Civil Engineering (Evaluating the Impact of Blast-Induced Damage on the Rock Load Supported by Liner in Construction of a Deep Shaft: A Case Study of Ventilation Shaft of ...)[J]. Journal of Engineering,2020,:.
[10]. Engineering - Civil Engineering; Data from K.N. Toosi University of Technology Provide New Insights into Civil Engineering (Measured and Predicted Durability and Mechanical Properties of Frozen-Thawed Fine Soils)[J]. Journal of Engineering,2020,:.
[11]. Engineering - Civil Engineering; Hong Kong University of Science and Technology Researchers Publish New Study Findings on Civil Engineering (Assessing construction labours' safety level: a fuzzy MCDM approach)[J]. Journal of Engineering,2020,:.
[12]. Engineering - Civil Engineering; Findings from Kyungpook National University Reveals New Findings on Civil Engineering (Image Denoising and Refinement Based On an Iteratively Reweighted Least Squares Filter)[J]. Journal of Engineering,2020,:.
[13]. Engineering - Civil Engineering; Researchers from Department of Civil and Environmental Engineering Report Details of New Studies and Findings in the Area of Civil Engineering (Influence of Motion Energy and Soil Characteristics On Seismic Ground Response of Layered Soil)[J]. Journal of Engineering,2020,:.
[14]. Engineering - Civil Engineering; Soochow University Researchers Discuss Findings in Civil Engineering [Mechanical Properties of Municipal Solid Waste Incinerator (MSWI) Bottom Ash as Alternatives of Subgrade Materials][J]. Journal of Engineering,2020,:.
[15]. Engineering - Civil Engineering; University of Zagreb Researcher Details New Studies and Findings in the Area of Civil Engineering (Classification of construction hazards for a universal hazard identification methodology)[J]. Journal of Engineering,2020,:.
[16]. Engineering - Civil Engineering; Studies from Wuhan Institute of Technology Yield New Data on Civil Engineering (Analysis of Sunshine Temperature Field of Steel Box Girder Based on Monitoring Data)[J]. Journal of Engineering,2020,:.
[17]. Engineering - Civil Engineering; North China University of Technology Researchers Provide New Study Findings on Civil Engineering (Effect of Straw Fiber Modification Methods on Compatibility between Straw Fibers and Cement-Based Materials)[J]. Journal of Engineering,2020,:.
[18]. Engineering - Civil Engineering; Recent Research from Texas Department of Transportation Highlight Findings in Civil Engineering (Impact of Weaving Segment Configuration Designs on Drivers' Acute Driving Stress: A Case Study on Houston Freeway Weaving Segments)[J]. Journal of Engineering,2020,:.
[19]. Engineering - Civil Engineering; Researchers at Southeast University Have Published New Study Findings on Civil Engineering (Liquefiable Ground Treatment Using Cruciform Section Probe Resonant Compaction Method: A Case Study in the Xitong Expressway, Eastern China)[J]. Journal of Engineering,2020,:.
[20]. Engineering - Civil Engineering; Study Findings from Taiyuan University of Technology Provide New Insights into Civil Engineering (Research On the Reinforcement Mechanism and Safety Monitoring of Heavy-duty Concrete-encased Cfst Columns)[J]. Journal of Engineering,2020,:.
[21]. Engineering - Civil Engineering; Research from National Kaohsiung University of Science and Technology Yields New Data on Civil Engineering (An improved time-cost trade-off model with optimal labor productivity)[J]. Journal of Engineering,2020,:.
[22]. Engineering - Civil Engineering; New Findings from Fuzhou University in the Area of Civil Engineering Described (Three-part Wedge Method for the Stability Calculation of Embankment Supported On Rigid Pile Foundation)[J]. Journal of Engineering,2020,:.
[23]. Engineering - Civil Engineering; New Civil Engineering Findings Has Been Reported by Investigators at University of Helsinki (This Has Been a Real Uphill Battle - Three Organisations for the Adoption of Last Planner System)[J]. Journal of Technology & Science,2020,:.
[24]. Engineering - Civil Engineering; New Civil Engineering Data Have Been Reported by Investigators at Indian Institute for Technology (A Modified Motion Planning Algorithm for Horizontal Highway Alignment Development)[J]. News of Science,2020,:.
[25]. Engineering - Civil Engineering; Reports from University of Cambridge Add New Data to Findings in Civil Engineering (Measurement of shear strength for marine clay)[J]. Chemicals & Chemistry,2020,:.
参考文献二
[26]. Engineering - Civil Engineering; Technical University Researchers Have Provided New Study Findings on Civil Engineering (Selected problems of thermal insulation of historical buildings)[J]. Ecology, Environment & Conservation,2020,:.
[27]. Engineering - Civil Engineering; Research in the Area of Civil Engineering Reported from Technical University (Inlet device with double exponential profile distributor for indoor air dispensation)[J]. Ecology, Environment & Conservation,2020,:.
[28]. Engineering - Civil Engineering; New Civil Engineering Study Findings Have Been Reported from Zhejiang University (Computer Vision-based Recognition of 3d Relationship Between Construction Entities for Monitoring Struck-by Accidents)[J]. Computer Technology Journal,2020,:.
[29]. Technology - Underground Space Technology; Study Data from State Key Laboratory of Disaster Reduction in Civil Engineering Provide New Insights into Underground Space Technology (Assessment and structural improvement on the performance of soil chamber system of EPB shield assisted with ...)[J]. Journal of Technology,2020,:.
[30]. Engineering - Civil Engineering; New Civil Engineering Study Findings Recently Were Published by Researchers at Technical University (Utilizing drone technology in the civil engineering)[J]. Journal of Technology,2020,:.
[31]. Engineering - Civil Engineering; New Civil Engineering Study Findings Have Been Published by Researchers at China University of Mining and Technology (Estimating the Uplift Bearing Capacity of Belled Piers Adjacent to Sloping Ground by Numerical Modeling Based on Field Tests)[J]. Journal of Mathematics,2020,:.
[32]. Engineering - Civil Engineering; Findings from Chang'an University Update Understanding of Civil Engineering (Pavement Defect Detection With Fully Convolutional Network and an Uncertainty Framework)[J]. Journal of Engineering,2020,:.
[33]. Engineering - Civil Engineering; Researchers from University of Science and Technology Beijing Detail Research in Civil Engineering (Experimental Study on Seepage Properties of Jointed Rock-Like Samples Based on 3D Printing Techniques)[J]. Journal of Engineering,2020,:.
[34]. Engineering - Civil Engineering; Reports Summarize Civil Engineering Study Results from Federal University Rio Grande do Sul (Model for planning and controlling the delivery and assembly of engineer-to-order prefabricated building systems: exploring synergies between Lean and ...)[J]. Journal of Engineering,2020,:.
[35]. Engineering - Civil Engineering; Research Data from Hohai University Update Understanding of Civil Engineering (Equivalent diameter of grouted micropile embedded in marine soft clay under lateral load)[J]. Journal of Engineering,2020,:.
[36]. Engineering - Civil Engineering; New Findings Reported from Polytechnic University of Valencia Describe Advances in Civil Engineering (Integrating HBIM models in the management of the public use of heritage buildings)[J]. Journal of Engineering,2020,:.
[37]. Engineering - Civil Engineering; Studies from University of Huddersfield Further Understanding of Civil Engineering [Lean construction and BIM in small and medium-sized enterprises (SMEs) in construction: a systematic literature review][J]. Journal of Engineering,2020,:.
[38]. Engineering - Civil Engineering; Study Data from French Institute of Science and Technology for Transport Development and Networks (IFSTTAR) Update Knowledge of Civil Engineering (Impact of Pile Roughness On Shaft Resistance In Sand)[J]. Journal of Engineering,2020,:.
[39]. Engineering - Civil Engineering; Findings on Civil Engineering Discussed by Investigators at New York University (NYU) (Owner requirements in as-built BIM deliverables and a system architecture for FM-specific BIM representation)[J]. Journal of Engineering,2020,:.
[40]. Engineering - Civil Engineering; Investigators from Federal University Rio Grande do Sul Target Civil Engineering (Behaviour of Cement-stabilised Silty Sands Subjected To Harsh Environmental Conditions)[J]. Journal of Engineering,2020,:.
[41]. Engineering - Civil Engineering; Data from University of Alberta Advance Knowledge in Civil Engineering (A Visual Dashboard To Monitor Bim Model Dynamics)[J]. Journal of Engineering,2020,:.
[42]. Engineering - Civil Engineering; Findings from University of Ghent Yields New Findings on Civil Engineering (Predicting sandy-clayey soil properties using electrical resistivity testing)[J]. Journal of Engineering,2020,:.
[43]. Engineering - Civil Engineering; Findings from Foshan University Provide New Insights into Civil Engineering (An Experimental Study of the Feasibility of Identifying the Impact Damages of Reinforced Concrete Piers Using a Modal Frequency Method)[J]. Journal of Engineering,2020,:.
[44]. Engineering - Civil Engineering; Study Results from University of Helsinki Broaden Understanding of Civil Engineering (Design-related Questions In the Construction Phase: the Effect of Using the Last Planner System In Design Management)[J]. Journal of Engineering,2020,:.
[45]. Engineering - Civil Engineering; Data on Civil Engineering Published by Researchers at University of Natural Resources and Applied Life Science (Likelihood of impact events in transport networks considering road conditions, traffic and routing elements properties)[J]. Journal of Engineering,2020,:.
[46]. Engineering - Civil Engineering; Shandong Jianzhu University Researcher Discusses Research in Civil Engineering (Strain Rate Effect on the Progressive Collapse Analysis of RC Frame Structure under Earthquake)[J]. Journal of Engineering,2020,:.
[47]. Engineering - Civil Engineering; New Civil Engineering Study Findings Recently Were Reported by Researchers at HeNan Polytechnic University (Analysis On Bearing Performance of Y-shaped Piles Under Compressive and Tensile Loading)[J]. Journal of Engineering,2020,:.
[48]Varvara Shubina Helbert,Laurent Gaillet,Thierry Chaussadent,Vincent Gaudefroy,Juan Creus. Rhamnolipids as an eco-friendly corrosion inhibitor of rebars in simulated concrete pore solution: evaluation of conditioning and addition methods[J]. Corrosion Engineering, Science and Technology,2020,55(2):.
[49]Gidday Bisrat Gissila,Mittal Satyendra. Improving the characteristics of dispersive subgrade soils using lime.[J]. Heliyon,2020,6(2):.
[50]Mostafa Seifan,Oluwaseun Deborah Dada,Aydin Berenjian. The Effect of Real and Virtual Construction Field Trips on Students’ Perception and Career Aspiration[J]. Sustainability,2020,12(3):.
参考文献三
[51]高明. 土木工程建设中结构与地基加固技术的运用[J]. 居舍,2019,(26):46.
[52]季佳林. 浅谈土木工程施工中钢结构技术的应用[J]. 居舍,2019,(26):48-49.
[53]马波. 分析土木工程中的绿色施工和可持续发展[J]. 居舍,2019,(26):15.
[54]阙明林. 土木工程道桥施工技术的管理措施浅析[J]. 地产,2019,(17):79.
[55]徐艳召. 土木工程BIM实验室的建设与教学分析[J]. 地产,2019,(17):140.
[56]何全华. 浅谈土木工程建筑中混凝土施工技术要点[J]. 地产,2019,(17):154-155.
[57]陈英. 土木工程钢结构施工技术的有关问题研究[J]. 地产,2019,(17):163-164.
[58]陆涛. 探微土木工程结构设计中的安全性与经济性[J]. 居舍,2019,(25):88.
[59]晁亚茹. BIM技术在土木工程中的应用具体措施探讨[J]. 居舍,2019,(25):38+157.
[60]苏渊文. 土木工程建筑施工技术级创新[J]. 居舍,2019,(25):65.
[61]梁腾飞,贺园园,杨瑞娟. 基于BIM的土木工程专业人才培养课程体系构建[J]. 知识经济,2019,(25):152-154.
[62]朱慧芹. 工程施工进度管理问题及策略探析[J]. 安徽建筑,2019,26(09):289-291.
[63]王凤超. 土木工程施工中起重机械的虚拟仿真系统研究[J]. 中国金属通报,2019,(08):241-242.
[64]植海. 高校土木工程材料课程实践教学的改革研究[J]. 智库时代,2019,(37):189+191.
[65]弓瑞杰. 土木工程施工中桩基础施工技术[J]. 建材与装饰,2019,(26):50-51.
[66]曹强. 土木工程中混凝土施工技术的应用研究[J]. 建材与装饰,2019,(26):16-17.
[67]郭玉珍. 土木工程专业职教本科人才培养模式的研究——以江西工业贸易职业技术学院为例[J]. 建材与装饰,2019,(26):144-145.
[68]胡涛. 土木工程施工中节能环保技术研究[J]. 工程建设与设计,2019,(16):186-187.
[69]陶涛涛. 土木工程中房建工程质量问题与控制策略分析[J]. 江西建材,2019,(08):205+207.
[70]苏星. 土木工程力学技术的控制与实现[J]. 江西建材,2019,(08):214+216.
[71]陶锋. 浅析利用信息化技术提升土木工程管理效果的策略[J]. 农家参谋,2019,(17):122.
[72]蒋雪峰. 土木工程施工管理中的问题及对策分析[J]. 全面腐蚀控制,2019,33(08):36-37+83.
[73]林波. 浅议土木工程混凝土施工技术应用[J]. 智能城市,2019,5(16):156-157.
[74]陈太洲. 土木施工中大体积混凝土裂缝成因及其防治措施思路构建[J]. 智能城市,2019,5(16):163-164.
[75]姚勇. 应用型转型背景下的土木工程人才培养模式研究与实践[J]. 嘉应学院学报,2019,37(04):121-123.
参考文献四
[76]洪义,曹志刚,李玲玲. 土木工程类《基础工程》教学改革——如何构建“三位一体”的课堂[J]. 教育现代化,2019,6(69):49-51.
[77]陈丽玲. 土木工程建筑中混凝土结构的施工技术[J]. 科学技术创新,2019,(24):104-105.
[78]王前芳. 试析路桥设计中的安全性和耐久性[J]. 科学技术创新,2019,(24):119-120.
[79]龚晨辉. 土木工程中混凝土施工技术的应用分析[J]. 住宅与房地产,2019,(24):177.
[80]王海良. 大数据背景下BIM技术在土木工程中的应用[J]. 住宅与房地产,2019,(24):160.
[81]姜昌军. 土木工程管理施工过程质量控制措施分析[J]. 中小企业管理与科技(下旬刊),2019,(08):9-10.
[82]孙海勇. 土木工程施工技术的创新及发展分析[J]. 建筑技术开发,2019,46(16):62-63.
[83]张新龙. 土木工程施工质量控制与安全管理的分析[J]. 门窗,2019,(16):186.
[84]高志强. 探讨土木工程施工中边坡支护技术的应用[J]. 门窗,2019,(16):71+73.
[85]孙桂芳. 土木工程建筑中大体积混凝土结构的施工技术探讨[J]. 门窗,2019,(16):89+91.
[86]冯士升. 土木工程中混凝土施工技术的应用[J]. 门窗,2019,(16):107.
[87]孙占春. 土木工程施工中防水防渗施工技术[J]. 门窗,2019,(16):113.
[88]王新明. 土木工程房建工程质量保障措施初探[J]. 门窗,2019,(16):162+165.
[89]邹恒静. 土木工程建筑中大体积混凝土结构的施工技术研究[J]. 门窗,2019,(16):93-94.
[90]李岩. BIM与VR技术在土木工程施工教学过程中的探索与实践[J]. 黑龙江科学,2019,10(16):142-143.
[91]苑连霞. “新工科”背景下土木工程专业建设的重要路径[J]. 科技资讯,2019,17(24):254+256.
[92]齐燕. 土木工程建筑结构设计中存在的问题与策略探析[J]. 中国石油和化工标准与质量,2019,39(16):142-143.
[93]赵甲荐. 土木工程应用型人才培养的“双师型”师资队伍建设研究[J]. 教育现代化,2019,6(68):76-78.
[94]李国栋. 超厚板壁复杂结构架空水池施工技术分析[J]. 居舍,2019,(24):81.
[95]何忠海. 基于现代理念下的土木工程施工管理思考[J]. 居舍,2019,(24):1.
[96]张秋雨. 土木工程施工中节能绿色环保技术探析[J]. 居舍,2019,(24):8.
[97]朱裕峰. 土木工程建筑结构设计的问题与解决方法探究[J]. 居舍,2019,(24):125.
[98]丁宁,石振波. 土木工程建筑中大体积混凝土结构的施工技术探讨[J]. 居舍,2019,(24):175.
[99]廖先根,朱德浩. 土木工程类高职实践性教学模式研究[J]. 居舍,2019,(24):188.
[100]马彬,牛海华,朱林伟. 虚拟仿真实验教学在土木工程专业教学中的分析与探索[J]. 大众科技,2019,21(08):108-110.
