地基中英文参考文献
  以下就是土木毕设网为大家精心整理的地基中英文参考文献50例。供大家学习。
参考文献
  [1]Verónica Sandoya,Sandra Saura-Mas,I?igo Granzow-de la Cerda,Gabriel Arellano,Manuel J. Macía,J. Sebastián Tello,Francisco Lloret. Contribution of species abundance and frequency to aboveground forest biomass along an Andean elevation gradient[J]. Forest Ecology and Management,2021,479:.
  [2]Paul W. Cleary,Rob D. Morrison,Matt D. Sinnott. Prediction of slurry grinding due to media and coarse rock interactions in a 3D pilot SAG mill using a coupled DEM + SPH model[J]. Minerals Engineering,2020,159:.
  [3]E. Jur?i?inová,M. Jur?i?in. Influence of multisite interaction on thermodynamics and ground-state degeneracies of frustrated magnetic systems with pyrochlore structure: An exact theoretical analysis[J]. Physica A: Statistical Mechanics and its Applications,2021,561:.
  [4]Long Chen,Yat-Sze Choy,Kai-Chung Tam,Cheng-Wei Fei. Hybrid microphone array signal processing approach for faulty wheel identification and ground impedance estimation in wheel/rail system[J]. Applied Acoustics,2021,172:.
  [5]P.-G. Reinhard,B. Schuetrumpf,J.A. Maruhn. The Axial Hartree–Fock + BCS Code SkyAx[J]. Computer Physics Communications,2021,258:.
  [6]Wenqiang Xu,Liangxiao Jiang,Chaoqun Li. Improving data and model quality in crowdsourcing using cross-entropy-based noise correction[J]. Information Sciences,2021,546:.
  [7]Li Lai,Dong Die,Ben-Xia Zheng,Quan Du. Growth mechanism and electronic and magnetic properties of Ag n Ti alloy clusters[J]. Journal of Physics and Chemistry of Solids,2021,148:.
  [8]Yanchuan Shao,Zongwei Ma,Jianghao Wang,Jun Bi. Estimating daily ground-level PM 2.5 in China with random-forest-based spatiotemporal kriging[J]. Science of the Total Environment,2020,740:.
  [9]Maria A. Zoran,Roxana S. Savastru,Dan M. Savastru,Marina N. Tautan. Assessing the relationship between ground levels of ozone (O 3 ) and nitrogen dioxide (NO 2 ) with coronavirus (COVID-19) in Milan, Italy[J]. Science of the Total Environment,2020,740:.
  [10]Sinyang Kim,Sang Mok Jung,Sungjune Jung,Hyun Woung Shin,Dong Soo Hwang. Sea urchin repelling Tannin– Fe III complex coating for ocean macroalgal afforestation[J]. Chemosphere,2021,263:.
  [11]Daheui Choi,Jangsun Hwang,Junah Bang,Seora Han,Taeho Kim,Yoogyeong Oh,Youngdeok Hwang,Jonghoon Choi,Jinkee Hong. In vitro toxicity from a physical perspective of polyethylene microplastics based on statistical curvature change analysis[J]. Science of the Total Environment,2021,752:.
  [12]李良勇,陈建峰,彭铭. 基于新型人工软土的加筋碎石桩复合地基承载特性模型试验[J]. 长江科学院院报,,:1-10.
  [13]崔希民,车宇航,赵玉玲,李培现,白志辉. 采动地表移动变形与建筑物损坏程度评价的再认识[J]. 煤炭学报,,:1-12.
  [14]陈亚北. 现浇箱梁支架设计与施工质量控制研究[J]. 科学技术创新,2020,(28):169-170.
  [15]肖立峰. 建筑工程岩土勘察和施工处理技术[J]. 大众标准化,2020,(18):15-16.
  [16]孙颢,石潇竹,刘海颖,李贺. 基于多参数稳定分布的GBAS垂直PL计算[J]. 系统工程与电子技术,,:1-8.
  [17]王安辉,章定文,丁选明,刘维正,朱子超. 桩筏连接形式对劲芯复合桩地震响应影响试验研究[J]. 中国公路学报,,:1-13.
  [18]孔祥东. 水利工程施工中软基基础处理技术分析[J]. 黑龙江科学,2020,11(18):96-97.
  [19]刘键. 建筑地基处理以及结构设计探讨[J]. 低碳世界,2020,10(09):66-67.
  [20]何劲闯. 建筑物抗震中建筑方案设计起到的作用分析[J]. 低碳世界,2020,10(09):84-85.
  [21]吴峰,李巍. 近海风力发电机桩基础的动力学研究[J]. 低碳世界,2020,10(09):114-115.
  [22]刘芳芳. 路桥工程中的软土路基施工技术要点[J]. 低碳世界,2020,10(09):131-132.
  [23]Geyang Song,Alec M. Marshall. Centrifuge Study on the Influence of Tunnel Excavation on Piles in Sand[J]. Journal of Geotechnical and Geoenvironmental Engineering,2020,146(12):.
  [24]Ying Tian,Xiang Liu,Sara George. Effects of Vertical Ground Motion on Seismic Performance of Reinforced Concrete Flat-Plate Buildings[J]. Journal of Structural Engineering,2020,146(12):.
  [25]Shaosheng Xu,Yaogang Zhang,Yong Wei,Guangjun Tian. Ground and excited state geometrical and optical properties of Au n (n = 2–13) nanoclusters: A first-principles study[J]. Computational and Theoretical Chemistry,2020,1190:.
  [26]Timothy Johnson,Donald Cameron,Gregory Moore,Chris Brien. Ground movement in a moderately expansive soil subject to rainfall infiltration through pervious paving[J]. Ecological Engineering,2020,158:.
  [27]Huajun Wang,Biying Liu,Feifan Yang,Feng Liu. Test investigation of operation performance of novel split-type ground source heat pump systems for clean heating of rural households in North China[J]. Renewable Energy,2021,163:.
参考文献二
  [28]Hongzhi Zhang,Zongwei Han,Gui Li,Mingzhen Ji,Xinlu Cheng,Xiuming Li,Lingyan Yang. Study on the influence of pipe spacing on the annual performance of ground source heat pumps considering the factors of heat and moisture transfer, seepage and freezing[J]. Renewable Energy,2021,163:.
  [29]Tawich Klathae,Nattaphop Tanawuttiphong,Weerachart Tangchirapat,Prinya Chindaprasirt,Piti Sukontasukkul,Chai Jaturapitakkul. Heat evolution, strengths, and drying shrinkage of concrete containing high volume ground bagasse ash with different LOIs[J]. Construction and Building Materials,2020,258:.
  [30]Zehua Ji,Meng Li,Liya Su,Yuansheng Pei. Porosity, mechanical strength and structure of waste-based geopolymer foams by different stabilizing agents[J]. Construction and Building Materials,2020,258:.
  [31]Zheng Tong,Jie Gao,Dongdong Yuan. Advances of deep learning applications in ground-penetrating radar: A survey[J]. Construction and Building Materials,2020,258:.
  [32]Zedi Zhang,Jia Xiao,Kaidong Han,Jialei Wang,Xiaoyan Hu. Study on the structural build-up of cement-ground limestone pastes and its micro-mechanism[J]. Construction and Building Materials,2020,263:.
  [33]Nurettin Alper Toprak,Ahmet Hakan Benzer,Cumhur Erdem Karahan,Ergin Sarp Zencirci. Effects of grinding aid dosage on circuit performance and cement fineness[J]. Construction and Building Materials,2020,265:.
  [34]Ponti Stefano,Cannone Nicoletta,Guglielmin Mauro. A new simple topo-climatic model to predict surface displacement in paraglacial and periglacial mountains of the European Alps: The importance of ground heating index and floristic components as ecological indicators[J]. Ecological Indicators,2021,120:.
  [35]Duc Ba Nguyen,Saud Shirjana,Md. Mokter Hossain,Iljeong Heo,Young Sun Mok. Effective generation of atmospheric pressure plasma in a sandwich-type honeycomb monolith reactor by humidity control[J]. Chemical Engineering Journal,2020,401:.
  [36]Antti Ahola,Arttu Muikku,Moritz Braun,Timo Bj?rk. Fatigue strength assessment of ground fillet-welded joints using 4R method[J]. International Journal of Fatigue,2021,142:.
  [37]Yonghao Tan,Lin Sha,Jun Qu,Jinqi Jiang,Jie Ren,Chenjie Wu,Zhigao Xu. Oleic acid as grinding aid and surface antioxidant for ultrafine zirconium hydride particle preparation[J]. Applied Surface Science,2021,535:.
  [38]Hongyu Shen,Liang Wang. Mechanism and properties of plasma nitriding AISI 420 stainless steel at low temperature and anodic (ground) potential[J]. Surface & Coatings Technology,2020,403:.
  [39]Chuan He,Yan Yin,Wuyi Wang,Kui Chen,Rong Mai,Hui Jiang,Xin Zhang,Chenwei Fang. Aircraft observations of ice nucleating particles over the Northern China Plain: Two cases studies[J]. Atmospheric Research,2021,248:.
  [40]R. Garibay-Alonso,J.L. Ricardo-Chávez,J.L. Rodríguez-López,J.L. Morán-López. Spin orbit coupling effects on the non-collinear magnetism of structurally relaxed Fe/Cu (001) thin films: First principles calculations[J]. Journal of Magnetism and Magnetic Materials,2020,514:.
  [41]P.S. Savchenkov,E.S. Clementyev,V.N. Lazukov,P.A. Alekseev. Dramatic impact of intermediate-valence impurity on induced magnetism in singlet ground state system PrNi[J]. Journal of Magnetism and Magnetic Materials,2020,514:.
  [42]Andrzej ?lebarski,Józef Deniszczyk,Elena Murashova,Dariusz Kaczorowski. Magnetic ground state in novel valence fluctuating compound Ce 2 RuGe: Electronic structure investigations[J]. Journal of Magnetism and Magnetic Materials,2020,514:.
  [43]Yuan Ma,Kang Zhu,Yanzhong Li,Fushou Xie. Numerical investigation on chill-down and thermal stress characteristics of a LH 2 tank during ground filling[J]. International Journal of Hydrogen Energy,2020,45(46):.
  [44]郭兴峰,刘鹏,李亮. 关于复合地基处理技术的应用现状及发展趋势探讨[J]. 绿色环保建材,2020,(10):87-88.
  [45]韩继军. 公路路基路面施工管理中常见问题及解决措施分析[J]. 绿色环保建材,2020,(10):89-90.
  [46]李凯. 房屋建筑工程施工技术及现场施工管理方法分析[J]. 绿色环保建材,2020,(10):119-120.
  [47]唐细明. 格构式塔吊基础在建筑施工中的应用[J]. 绿色环保建材,2020,(10):125-126.
  [48]尹烨. 高层建筑地基处理与工程质量管理手段探究[J]. 绿色环保建材,2020,(10):155-156.
  [49]郭宁. 建筑地基处理中灌注桩后注浆工法的运用分析[J]. 绿色环保建材,2020,(10):157-158.
  [50]杨兵. 水利水电基础工程施工中不良地基的处理技术[J]. 绿色环保建材,2020,(10):165-166.
Current Value 4081
Update Date 2020-10-13
