土木工程中英文文献
  以下是土木毕设网小编为大家搜集整理的土木工程外文文献,供大家参考和借鉴!更多内容尽在参考文献栏目!
参考文献
  [1]Airong Chen,Xin Ruan,Dan M.Frangopol.Life-Cycle Civil Engineering:Innovation,Theory and Practice:Proceedings of the 7th International Symposium on Life-Cycle Civil Engineering(IALCCE 2020),October 27-30,2020,Shanghai,China[M].CRC Press:2020-12-15.
  [2]Engineering-Civil Engineering;Reports from Xi'an University of Architecture and Technology Highlight Recent Research in Civil Engineering(A Theoretical Calculation Method of the Unsupported Span for the Shallow Tunnel in the Soft Stratum)[J].Journal of Engineering,2020,:
  [3]Engineering-Civil Engineering;Studies from Xi'an Jiaotong University in the Area of Civil Engineering Published(A Review of Cracking Behavior and Mechanism in Clayey Soils Related to Desiccation)[J].Journal of Engineering,2020,:
  [4]Engineering-Civil Engineering;Research Reports from Chang'an University Provide New Insights into Civil Engineering(Performance of Super-Large-Span Tunnel Portal Excavated by Upper Bench CD Method Based on Field Monitoring and Numerical Modeling)[J].Journal of Engineering,2020,:
  [5]Engineering-Civil Engineering;Researchers'from Chang'an University Report Details of New Studies and Findings in the Area of Civil Engineering(Analysis of Land Surface Temperature Evolution Based on Regional Road Scope)[J].Journal of Engineering,2020,:
  [6]Engineering-Civil Engineering;Findings from Xi'an University of Architecture and Technology Broaden Understanding of Civil Engineering(Seismic Performance of a New Type of Reinforced Concrete Energy Dissipation Structure)[J].Journal of Engineering,2020,:
  [7]Engineering-Civil Engineering;Studies from Chang'an University Yield New Data on Civil Engineering(Mechanical and Deformation Characteristics and Optimization of Support Parameters for Superlarge-Span Tunnel:A Case Study from Laohushan Tunnel)[J].Journal of Engineering,2020,:
  [8]Engineering-Civil Engineering;Research Results from Chang'an University Update Understanding of Civil Engineering(The Response of Urban Travel Mode Choice to Parking Fees considering Travel Time Variability)[J].Journal of Engineering,2020,:
  [9]Engineering-Civil Engineering;Recent Findings in Civil Engineering Described by Researchers from Chang'an University(Effects of Cement Content,Curing Period,Gradation,and Compaction Degree on Mechanical Behavior of Cement-Stabilized Crushed Gravel Produced via Vertical...)[J].Journal of Engineering,2020,:
  [10]Engineering-Civil Engineering;Reports from Chang'an University Describe Recent Advances in Civil Engineering(Bonding Performance and Evaluation of Basalt Fiber Asphalt Macadam Seal)[J].Journal of Engineering,2020,:
  [11]Engineering-Civil Engineering;Studies from Xi'an University of Architecture and Technology in the Area of Civil Engineering Described(The Physicomechanical Deterioration Characteristics and Mesoscopic Damage Analysis of Sandstone under Acidic Environment)[J].Journal of Engineering,2020,:
  [12]Engineering-Civil Engineering;New Civil Engineering Findings Reported from Xi'an Technological University(Influence of Blasting Vibrations Generated By Tunnel Construction On an Existing Road)[J].Journal of Engineering,2020,:
  [13]Engineering-Civil Engineering;Reports from Iran University of Science and Technology Advance Knowledge in Civil Engineering(Predicting the Compressive Stress-strain Curve of Frp-confined Concrete Column Considering the Variation of Poisson's Ratio)[J].Journal of Technology&Science,2020,:
  [14]Engineering-Civil Engineering;Research Data from Xi'an University of Science and Technology Update Understanding of Civil Engineering(Numerical Simulation of the Effect of Dynamic Stress on the Rock Surrounding a Mine Roadway)[J].Journal of Mathematics,2020,:
  [15]Engineering-Civil Engineering;Studies in the Area of Civil Engineering Reported from Xi'an University of Science and Technology(Exploring the Occurrence of Clogging in Highly Permeable Coarse Soils of Dam Foundations)[J].Journal of Engineering,2020,:
  [16]Engineering-Civil Engineering;Research on Civil Engineering Discussed by Researchers at Chang'an University(Flexural Capacity and Behavior of RC Hollow Bridge Beams after a Time Service of 24 Years)[J].Journal of Engineering,2020,:
  [17]Engineering-Civil Engineering;New Findings from Chang'an University in the Area of Civil Engineering Described(Application of the Upper-Bench CD Method in Super Large-Span and Shallow Tunnel:A Case Study of Letuan Tunnel)[J].Journal of Engineering,2020,:
  [18]Engineering-Civil Engineering;Xi'an University of Science and Technology Researchers Describe Recent Advances in Civil Engineering(Determining the Seepage Stability of Fractured Coal Rock in the Karst Collapse Pillar)[J].Journal of Engineering,2020,:
  [19]Engineering-Civil Engineering;Research from Xi'an University of Technology Provides New Study Findings on Civil Engineering(Mechanical Characteristics and Failure Characteristics of Jointed Rock under Axial Unloading and Radial Unloading)[J].Journal of Engineering,2020,:
  [20]Engineering-Civil Engineering;Xi'an University of Science and Technology Researchers Discuss Findings in Civil Engineering(Deterioration of the Internal Structure of Loess under Dry-Wet Cycles)[J].Journal of Engineering,2020,:
  [21]陶然.土木工程结构的设计与施工策略[J].住宅与房地产,2020,(21):93.
  [22]祁海玉.土木工程施工项目质量管理的措施分析[J].住宅与房地产,2020,(21):147.
  [23]冯健雪,王林均,杨想红,张吉.新工科背景下地方院校土木工程专业能力探索与课程体系构建[J].科教导刊(下旬刊),2020,(21):27-28.
  [24]英鹏程.大数据技术及其在土木工程中的应用[J].居舍,2020,(21):60-61.
  [25]丁点点,樊猛.基于BIM技术的土木工程专业实践教学改革研究[J].教育教学论坛,2020,(29):192-193.
参考文献二
  [26]白煜.土木工程施工中节能环保技术应用[J].砖瓦,2020,(07):113+115.
  [27]孟淑美.土木工程管理与工程造价控制[J].工程技术研究,2020,5(13):162-163.
  [28]钟灵芳,郑生.新时期土木工程专业培养模式初探——以福州外语外贸学院为例[J].四川建材,2020,46(07):235-236.
  [29]陈莉霞.论机械自动化在土木工程施工中的应用[J].河北农机,2020,(07):53.
  [30]张明明.浅谈西班牙语土木工程翻译实践中口译与笔译的异同[J].佳木斯职业学院学报,2020,36(07):114-115.
  [31]韩敬文.土木工程施工中节能绿色环保技术研究[J].大众标准化,2020,(13):85-86.
  [32]马世嫒,唐勇.“人工智能+土木工程”研究生培养模式研究[J].中国多媒体与网络教学学报(上旬刊),2020,(07):129-131.
  [33]金根.土木工程施工中的质量控制措施[J].中国高新科技,2020,(13):98-99.
  [34]赵平.土木工程建筑施工中的边坡支护技术[J].建筑技术开发,2020,47(12):45-46.
  [35]龙叙强.现代土木工程建设管理以及未来发展方向[J].居舍,2020,(18):131-132.
  [36]方洛.土木工程施工中节能绿色环保技术探析[J].建材与装饰,2020,(18):40+43.
  [37]崔鹏.试论土木工程房屋建筑施工的质量管理[J].建材与装饰,2020,(18):189+192.
  [38]刘涛.基于创新导向的三级实践教学体系研究——以厦门大学土木工程专业为例[J].当代教育实践与教学研究,2020,(12):182-183.
  [39]第十五届中国土木工程詹天佑奖获奖工程:南宁·瀚林美筑[J].煤气与热力,2020,40(06):32.
  [40]第十五届中国土木工程詹天佑奖获奖工程:马来西亚槟城第二跨海大桥[J].煤气与热力,2020,40(06):11.
  [41]陈忠全.提升土木工程施工项目质量管理的相关策略研究[J].居舍,2020,(17):119-120.
  [42]刘阳,周南.土木工程建筑节能的重要性研究[J].建材与装饰,2020,(17):122+124.
  [43]张益晋.分析土木工程管理与工程造价的有效控制[J].建材与装饰,2020,(17):141+144.
  [44]阚超.土木工程施工技术中存在的问题与创新[J].建筑技术开发,2020,47(11):47-48.
  [45]张晓宏.土木工程施工中质量控制的重要性及策略研究[J].中国高新科技,2020,(12):50+68.
  [46]钱泓阳.土木工程混凝土施工技术及质量管控研究[J].砖瓦,2020,(06):168-169.
  [47]任宏伟,陈建伟,刘岩.军民融合背景下高校土木工程专业人才培养机制研究[J].教育教学论坛,2020,(24):203-204.
  [48]黄明星.房屋建筑土木工程的施工质量管理[J].中阿科技论坛(中英阿文),2020,(06):39-40.
  [49]苏海.土木工程施工项目质量管理对策研究[J].技术与市场,2020,27(06):154-155.
  [50]陈更强,王淑桃.土木工程建筑施工技术的创新与管理——评《土木工程施工》[J].水利水电技术,2020,51(06):199.
Current Value 2643
Update Date 2022-02-08
