酒店给水排水及消防工艺设计论文摘要范文
  以下是土木毕设网小编为大家搜集整理的酒店给水排水及消防工艺设计论文摘要范文,供大家参考和借鉴!!
  该楼为XX市XX大酒店。地上五层,建筑总高度为15.50米,总面积为3500平方米。大楼给水水源来自县自来水公司,其市政给水管网水压为0.20Mpa。
  本设计包括给水系统、排水系统、消防系统和热水系统。该宾馆给水管网常年可提供的压力不能满足本建筑的生活用水需要,故采用分区给水方式。下区由市政管网直接供水,上区给水系统采用水池、水泵、水箱结合的给水方式,屋顶设生活与消防共用水箱,其给水管材采用PP-R给水管。排水系统采用生活污水和生活废水合流排放,普通伸顶通气,由于城市污水处理不够完善,则排水须设化粪池,排水管采用PVC管。消防系统包括消火栓系统、自动喷水灭火系统及手提灭火装置。消火栓系统管网竖向成环状,采用临时高压给水系统,自动喷水灭火系统采用独立的湿式自动喷水灭火系统,消防前十分钟的水量由高位水箱提供,消防管材采用普通钢管。热水系统采用容积式水加热器,上行下给供水。管材选用不锈钢管。
  [关键词]宾馆建筑给水排水设计
  This building ascends for The Ziran hotel in XX.There are five layers on ground,the total high degree of the building is 15.50 m,total area is 3500㎡.The headwater of the Mansion water supply comes from the county city running water company,the water pressure of its municipal water pipe net to 0.20 MPa.
  The design includes a water supply system,drainage system,fire protection systems and hot water systems.The hotel to the water supply network perennial pressure can not meet domestic water needs of the building,so the regional water supply.Zone of direct water supply from the municipal pipe network on the Water System water supply reservoirs,pumps,water tanks combined with the roof set up a shared life and fire tank,the water supply pipe PP-R water supply pipe.Drainage system with sewage and domestic wastewater confluence emissions ordinary stretch of roof ventilation,inadequate municipal sewage treatment,drainage shall be located a septic tank,drain pipe with PVC pipe.The fire protection system including fire hydrant system,automatic sprinkler systems and portable fire fighting equipment.Vertical fire hydrant system pipe network into the ring,the use of temporary high pressure water supply systems,automatic sprinkler system with an independent water supply system,using a wet automatic sprinkler system,fire ten minutes the amount of water provided by the high water tank.The fire tubes using ordinary steel.Fire fighting system pumps-tank water supply,fire tube steel pipe.The hot water system uses volumetric water heaters,upstream to the water supply.Pipe made of stainless steel pipe.
  [Key Words]Guest house Building Water Supply Drain Design
Current Value 1389
Update Date 2023-04-02
