某公司4层框架结构商务楼毕业设计(计算书+图纸)[面积4000]
摘  要
办公楼根据设计要求为四层混凝土框架结构,在设计过程中,首先要从建筑的场地上考虑,要有合理的布局,符合规范的进出口通道,以及消防规范。其次从建筑设计角度而言,外立面的美观是不可忽视的。内在的空间布局及建筑规范等方面的知识的也要相结合,对商务楼所具备的功能能更透彻的去了解,要在经济合理并合格国家的法律规范的情况完成建筑设计。
本设计主要包括建筑设计和结构设计两部分。建筑设计,包括平面定位图设计、平面设计、立面设计、剖面设计。结构设计,框架结构设计主要包括:结构选型,梁、柱、墙等构件尺寸的确定,重力荷载计算、横向水平作用下框架结构的内力和侧移计算、竖向荷载作用下横向框架的内力分析、内力组合、截面设计、基础设计。其中,基础设计又包括基础选型、基础平面布置、地基计算等。
在设计的过程中我严格按照最新规范及有关规定进行设计,其中采用的计算
方法均参照有关书籍。
关键词    办公楼设计 , 框架结构 , 结构计算
This design implementation “practical, safe, is economical, is artistic” the principle of design.According to the architectural design standard, considered earnestly affects the design each factor.According to structure and building overall and detail relations.
This design after determination frame layout, has carried on the level first the load generation of tabular value computation, extracts the wind load with the D value law the function, then uses the bending moment two methods of distribution to calculate the vertical load (dead load and live load) under the function structure endogenic force, and discovers most disadvantageous group of or a several group of endogenic force combination. Selects the safest result computation to match the muscle and to draw a chart.In addition has also carried on in the structure plan room the staircase design.Has completed the even platen, the carriage board, component and so on platform Liang endogenic forces and matches the muscle computation and the construction drawing plan.Carried on to the floor has matched the muscle computation, this design used the pile foundation, received Taiwan and the pile to the foundation has carried on the stress and matches the muscle computation.
The entire structure in the design process, the strict deference related specialized standard request, the reference correlation data and the related newest national standards standard, carries on the synthesis comprehensive scientific nature consideration to design each link.In brief, is suitable, the security, the economy, easy to operate is this design principle.Designs the reasonable feasible construction structure plan is the scene construction important basis.
Keywords  office-building ,Frame structure , structural calculation
建筑面积:4000m2
建筑层数:4层
建筑高度:15.6m
文件内容:计算书+图纸+开题报告
计算书.pdf
QQ截图20151127225520.png QQ截图20151127225531.png QQ截图20151127225541.png QQ截图20151127225651.png QQ截图20151127225511.png QQ截图20151127225636.png
Current Value 12229
Update Date 2015-11-27
