某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154]
随着我国经济和技术的发展,带动了我国城市建设的发展,从而要求建筑物所能达到的高度与规模不断地增加,为城市风景和节约国土资源贡献力量。但是,建筑物高度越大受到的风荷载与地震作用的影响也就越大。
本设计为当丹东市安馨家园高层住宅楼,该住宅楼总建筑面积为8154㎡。主体结构共11层,每层层高为3.0m,满足住宅的设计要求,形成一梯(两电梯)3户,内部为套间式。走廊的宽度采用1.8m。室内外高差为0.45m。本建筑主体结构为高层住宅楼,设计时应主要考虑水平地震作用及竖向荷载作用,满足顶点位移及各层位移限制要求。
本设计包括建筑设计和结构设计两大部分。在建筑设计中,应主要考虑建筑的使用性能,并满足安全性、适用性及耐久性要求。按照每间住宅的布置以及走廊的布置确定。结构设计中,主要进行了剪力墙几何特征及刚度计算、重力荷载计算、水平荷载计算、风荷载计算、结构水平位移计算、内力组合及主要墙体截面配筋等,并绘制配筋图及各部位的细部详图。
关键词:高层住宅楼;剪力墙结构;结构设计;建筑设计
As China's economic and technological development, promote the development of China's urban construction, which can meet the requirements of building height and size of the increase, for the urban landscape and contribute to conservation of land resources. However, the greater the building height by the wind loads and seismic effects of the greater.
The design for the district in Dandong city Anxin high-rise building, which houses a total construction area of 8,154 square meters. The main structure of a total of 11, each for the high layers of 3.0 m, designed to meet the domestic demand, create a ladder (two elevators) 3, for the internal-suites. Corridor width of a 1.8 m. Indoor and outdoor height difference is 0.45 m. The main structure for building high-rise residential buildings, the main consideration when designing the level of seismic and vertical load, displacement and to meet peak demands on each floor displacement limit.
design of two major parts. In architectural design, construction should be the main consideration of the use of performance and meet safety, suitability and durability requirements. In accordance with the layout of each residential and layout of the corridors identified. Structural design, the main characteristics of a shear wall and geometric rigidity, the gravity load, the level of load, wind loads, the structure of the level of displacement, the combination of internal forces and the main section of wall reinforcement, and reinforcement plans and mapping Each part of the detail Xiangtu.
Key words: high-rise residential buildings; shear wall structure; structural design; architectural design
建筑面积:8154m2
建筑层数:11层
建筑高度:35.4m
结构类型:剪力墙结构
建筑结构毕业设计-某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154](1) 毕业设计 .pdf
建筑结构毕业设计-某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154](2) 建筑结构毕业设计-某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154](3) 建筑结构毕业设计-某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154](4) 建筑结构毕业设计-某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154](5)
建筑结构毕业设计-某市小区11层住宅楼建筑结构设计(计算书+图纸)[面积8154](6)
Current Value 12463
Update Date 2015-11-27
