严寒地区隧道围岩冻融状况分析的导热与对流换热模型
严寒地区隧道围岩冻融状况分析的导热与对流换热模型) T) V. y& i! t0 Y! H3 p
摘    要) ]$ U. L- ~2 K4 o/ b7 `/ z
通过对严寒地区隧道现场基本气象条件的分析,建立了隧道内空气与围岩对流换热及固体导热的综合模型;用此模型对大兴安岭西罗奇2号隧道的洞内气温分布进行了模拟计算,结果与实测值基本一致;分析预报了正在开凿的祁连山区大坂山隧道开通运营后洞内温度及围岩冻结、融化状况.
% O: w0 g- ~2 `+ q关键词   严寒地区隧道   导热与对流换热   冻结与融化
# |2 u0 y; ?# q3 [0 z7 F. k1 N    在我国多年冻土分布及邻近地区,修筑了公路和铁路隧道几十座.由于隧道开通后洞内水热条件的变化;,普遍引起洞内围岩冻结,造成对衬砌层的冻胀破坏以及洞内渗水冻结成冰凌等,严重影响了正常交通.类似隧道冻害问题同样出现在其他国家(苏联、挪威、日本等)的寒冷地区.如何预测分析隧道开挖后围岩的冻结状况,为严寒地区隧道建设的设计、施工及维护提供依据,这是一个亟待解决的重要课题.  \6 M% H  Q. D; R5 s
+ Y$ R( W8 \3 C9 r2 q, I$ x/ uAbstract1 k6 z0 V3 W* E, s% _: {9 P
Based on the analyses of fundamental meteorological and hydrogeological conditions at the site of a tunnel in the cold regions, a combined convection-conduction model for air flow in the tunnel and temperature field in the surrounding has  been constructed. Using the model, the air temperature distribution in the Xiluoqi No. 2 Tunnel has been  simulated numerically. The simulated results are in agreement with the data observed. Then, based on the in situ conditions of sir temperature, atmospheric pressure, wind force, hydrogeology and engineering geology, the air-temperature  relationship between the temperature on the surface of the tunnel wall and the air temperature at the entry and exit of the  tunnel has been obtained, and the freeze-thaw conditions at the Dabanshan Tunnel which is now under construction is  predicted.* T* |9 Y& \0 O9 V7 c
Keywords: tunnel in cold  regions, convective heat exchange and  conduction, freeze-thaw.+ D) l. V) w+ l$ ]
A number of highway and railway tunnels have been constructed in the permafrost regions and their neighboring areas in China. Since the hydrological and thermal conditions changed after a tunnel  was excavated,the surrounding wall rock materials often froze, the frost heaving caused damage to the liner layers and seeping water froze into ice diamonds,which seriously interfered with the communication and transportation. Similar problems of the freezing damage in the tunnels also appeared in other countries like Russia, Norway and Japan .Hence it is urgent to predict the freeze-thaw conditions in the surrounding rock materials and provide a basis for the design,construction and maintenance of  new tunnels in cold regions.- P0 n* d- f6 C( M. S3 _
下载完整外文译文,纯word格式
Current Value 12263
Update Date 2015-11-28
