[水利水电毕业设计] 水利枢纽工程大坝水电站施工导流毕业设计(设计书+图纸)
摘     要
林江是我国大河流之一 ,其干流全长700公里,流域面积17400平方公里;楚河是林江的重要支流,流经林江的上下游地带,全长250公里,流域的面积为7200平方公里。楚河开发计划是配合林江而制定的。楚河楚林水利枢纽就建立在楚河和林江汇流处的楚林。
枢纽属一等工程,以防洪和发电为主,兼有航运等综合效益。其主要建筑物有:混凝土实心重力坝、引水建筑物、泄洪建筑物、放空建筑物、过坝建筑物和电站厂房等
枢纽按千年一遇洪水设计,五千年一遇洪水校核。水库正常蓄水位178.0米,设计洪水位179.3米,校核洪水位180.13米。电站装机3台2.4万千瓦,总装机72000千瓦。船闸可以保证80吨级驳船通航。
主体建筑物实体重力坝坝顶高程182.04米,最大坝高46.04米;泄洪采用表孔,共三孔,每孔宽12米,堰顶高程170.92米;放空采用深孔,设一孔,宽3.5米,高4米,底板高程151米;电站引水采用坝内压力钢管,钢管直径4.5米;电站厂房为坝后式。
本设计对枢纽的主体建筑物进行了认真的方案比选和详细的尺寸设计,并对所设计的建筑物进行了安全校核,保证建筑物的安全运行。同时对水电站和施工导流进行了简要的设计。
[关键词]林江 楚河 楚林 水利枢纽 大坝
Linjiang River is one of the large stream flow in our country, which has 700 kilometers long, and drainage area covers about 174000 km2. Chuhe River, which is on the upstream of the Linjiang River, is the most important anabranch on the Linjiang River, it has 500 kilometers long and it’s drainage area covers 7200 km2. The development plan of Chuhe River is determined on the Linjiang River. The Chuhe Chulin water project plan is built at the Chulin, of which the accordant junction of Chuhe River and Linjiang River.
The Chuhe Chulin water project plan is the first class project, it’s main functions are flood control and power generation. The main building includes: the concrete gravity dam, the diversion head building, the emptying outlet building and water power plant etc.
Water project plan is designed according to meeting flood design once in millennium, and  meet flood check once in five thousand years. The  normal water level of the project is 178.0m, the design flood level is 179.3m, and the check flood level is 180.13m.The total volume of the power generation units is 72000KW. The ship box can guarantee that 80 tons of barges get through.
This design has compared several available projects earnestly and design detailed size. At the same time it checks the safety, and  ensure the safe operation of the building. Simultaneously, the paper design the water power station and diversion work briefly.
[Keywords] Linjiang River   Chuhe River   Water project plan Dam
坝址地形
在本坝址地区,河床狭窄,仅一百多米宽,但随着高程之增高两岸便趋于平坦,两岸高度在200米以上,海拔高程在400米以上,在坝址处右岸较左岸为陡,右岸平均坡度为0.5左右,右岸为0.4左右,在坝址位于河弯的下游,在坝址上游十余公里有开阔地带,为形成水库的良好条件。
坝址地质
该区地质构造简单,主要岩层为黑色硅质页岩和燧石,上有3~9米左右的覆盖层,系河沙卵石,近风化泥土层及崩石,其岩层性质为:
黑色硅质页岩:属沉积岩,为硅质胶结物之页岩,根据勘测结果,该岩层性坚硬致密,仅岩石上层10~18米深度存在有裂隙和节理,不很严重,但需加以处理。经过压水实验,岩石之间单位吸水量为0.1公升/分钟。
燧石:其岩层不宽,分布于左岸,岩性较黑色硅质岩为弱,岩层走向:左岸为南30°西,倾角为50°~70°,倾向正向上游:
在坝址处,据目前资料未发现断层。
硅质页岩的力学性质:
(1)天然含水时的平均容重                2500公斤/立方米
(2)极限抗压强度:                                1000~1200公斤/立方厘米
(3)牢固系数                                                f=10~12
坝轴线岩层剖面图见蓝图。
部分内容展示
Current Value 12318
Update Date 2016-11-12
