某煤炭培训中心6层综合楼毕业设计(计算书+图纸+施组)[面积5000]
建筑面积:5000m2
建筑层数:6层
建筑高度:23.95m
文件内容:计算书+施组+图纸
综合运用所学专业知识,进行了章丘煤炭培训中心(钢结构方案三)的建筑设计、结构设计和施工组织设计。本工程为层高为3.9m,建筑高度为23.95m,建筑面积6000 。建筑设计力求简洁明快,具有时代感并与周围环境相结合,主体采用钢框架结构,钢筋混凝土楼板。首先确定结构方案并进行荷载统计、梁柱截面选择及刚度验算,然后计算风载作用下的框架内力及恒载、活载作用下的框架内力,经内力组合后得出构件的最不利组合内力,最后进行梁、柱截面验算、节点设计、楼板、楼梯配筋计算,绘制施工图。计算竖向荷载效应时采用分层法,计算水平荷载效应时采用D值法;在荷载组合时,考虑以可变荷载效应控制的组合和以永久荷载效应控制的组合方式;在活荷载计算过程中,采用满布荷载法;框架节点设计采用栓焊混合连接的方式;基础采用柱下独立基础。在施工组织设计中,结合建筑、结构情况将各层分为三个流水施工段。
关键词: 建筑设计;钢框架;内力分析;节点设计;施工组织设计
   Based on the professional knowledge for learned, building of Zhangqiu Coal Training Center was designed. The works include three parts: architecture design, structure design and construction design. The height of every story is 3.9m and the height of the whole building is 23.95m. The total area is 6000 .Architecture design tries hard for simple and clear, which has the ages feels and assort with surroundings environment. Steel frame and reinforce concrete floor were used in the structure. Firstly, the size of the beam and column was determined by the type of the structure and the calculation of the loads. Secondly, the inner forces of the frame under the wind load,  the dead load, and the living loads were analyzed separately. By the combination of the inner forces, the most dangerous forces can be got, and then the steel beam, steel column, the frame connections and reinforce concrete floor can be designed. After these, the drawing can be made. In the progress of internal force analysis, the vertical forces are calculated by the layer-wise method, and the horizontal forces are calculated by the D method. In the process of the live load calculation, full load is used. Mixed connection with welding and bolts was used in steel frame, and independent foundation under column was adopted. In the part of the construction organization design, based on the architecture design and structure design,  construction of each layer was divided into three segments.
Key Words: architecture design; steel frame; internal force analysis; connection design; construction organization design
某煤炭培训中心6层综合楼毕业设计(计算书 图纸 施组)[面积5000].pdf
QQ截图20151030220449.png QQ截图20151030220505.png QQ截图20151030220542.png QQ截图20151030220524.png
Current Value 13006
Update Date 2015-10-30
