跨径20m混凝土T型简支梁桥毕业设计(计算书+图纸)
内容提要
本设计是xxx河大桥设计。根据设计任务书的要求和桥梁设计规范的规定,经初选后,本设计提出了预应力混凝土连续梁桥、拱桥、混凝土T型简支梁桥三个比选方案。比选后,混凝土T型简支梁桥成为推荐方案。
本设计,首先进行桥型方案比选,再对主桥进行总体结构设计,然后对上部结构进行内力、配筋计算及验算,最后对下部结构进行计算及验算。
本设计,按照设计任务的要求,有一个比较详细的设计与计算过程,得出的结论准确,绘制了施工图,符合设计任务的要求。
关键词:T型简支梁桥;混凝土;推荐方案;施工图
Summary of contents
The paper is the design of Ou Chi Bridge in Zhuzikou. According to a requirement of design and the regulation of specifications for highway bridge design,by primary selection, The design put forward three programs that are the prestressed concrete continuous girder bridge, arch, concrete T-girder simple supported beam-bridge than the election. Than after the election, concrete T-girder simply supported beam-bridge as a programs recommended.
The paper, First carry on bridge-program selection,the second carry on the main bridge to the overall structural design, and then the upper part of the structure of the internal forces, reinforced the calculation and checking, the final structure of the lower part of the calculation and checking.
This paper, in accordance with the requirements of design, there is a more detailed design and calculation process, arrive at accurate conclusions, rendering the working drawings, with the design tasks.
Keywords: T-girder simple supported beam-bridge; concrete; Recommended programs; working drawings
设计跨径:20m
净宽:7+2×1.0m
Current Value 12944
Update Date 2015-11-09
