土木论文参考文献
  以下就是土木毕设网为大家精心整理的土木论文参考文献50例。供大家学习。
参考文献
  [1]. Engineering - Civil Engineering; Shahid Rajaee Teacher Training University Details Findings in Civil Engineering (Retrofit of Simple Welded Connections Against Progressive Collapse)[J]. Journal of Engineering,2020,:.
  [2]. Engineering - Civil Engineering; Research from Fujian Agriculture and Forestry University in the Area of Civil Engineering Published (Research on investment risk influence factors of prefabricated building projects)[J]. Journal of Engineering,2020,:.
  [3]. Engineering - Civil Engineering; Studies from University of Leeds in the Area of Civil Engineering Described (Imposed Loading Effects On Reinforced Concrete Walls Restrained At Their Base)[J]. Journal of Engineering,2020,:.
  [4]. Engineering - Civil Engineering; Research Study Findings from Zhengzhou University Update Understanding of Civil Engineering (Seismic Vulnerability Analysis of Multispan Continuous Bridges Subjected to Mainshock-Aftershock Earthquake Sequences)[J]. Journal of Engineering,2020,:.
  [5]. Engineering - Civil Engineering; Research from Jilin University Provides New Data on Civil Engineering (Flexural Behavior of Fiber-Reinforced Self-Stressing Concrete T-Shaped Composite Beams)[J]. Journal of Engineering,2020,:.
  [6]. Engineering - Civil Engineering; Studies from Jilin University Yield New Data on Civil Engineering (Modelling Triaxial Tests On Fibre-reinforced Sands With Different Fibre Orientations Using the Discrete Element Method)[J]. Journal of Engineering,2020,:.
  [7]. Engineering - Civil Engineering; Reports from Anhui University of Science and Technology Advance Knowledge in Civil Engineering (State Judgement Model of the Coal and Rock Medium and Its Engineering Application)[J]. Journal of Engineering,2020,:.
  [8]. Engineering - Civil Engineering; Studies from Southwest Jiaotong University Describe New Findings in Civil Engineering (Field Test On Uplift Bearing Capacity of Rock-socketed Belled Piles)[J]. Journal of Engineering,2020,:.
  [9]. Engineering - Civil Engineering; Studies from Ludong University Add New Findings in the Area of Civil Engineering (Analysis of Cyclic Response of Bucket Foundations Based on Simplified Kinematic Hardening Model)[J]. Journal of Engineering,2020,:.
  [10]. Engineering - Civil Engineering; Researchers at Korea Institute of Civil Engineering and Building Technology Have Reported New Data on Civil Engineering (Effect of Probability Distribution-based Physical Habitat Suitability Index On Environmental-flow Estimation)[J]. Journal of Engineering,2020,:.
  [11]. Engineering - Civil Engineering; Reports from Henan Polytechnic University Highlight Recent Research in Civil Engineering (Research on Surface Failure Law of Working Faces in Large Mining Height and Shallow Buried Coal Seam)[J]. Journal of Engineering,2020,:.
  [12]. Engineering - Civil Engineering; Studies from Anhui University of Science and Technology Describe New Findings in Civil Engineering (Physics and Dynamics Characteristics and Energy Analysis of Freeze-Thaw Limestone)[J]. Journal of Engineering,2020,:.
  [13]. Engineering - Civil Engineering; Reports from Xi'an University of Technology Provide New Insights into Civil Engineering (Experimental Study On the Mechanical Behaviour of Natural Loess Based On Suction-controlled True Triaxial Tests)[J]. Journal of Engineering,2020,:.
  [14]. Engineering - Civil Engineering; Research from Nanchang University Yields New Study Findings on Civil Engineering (Bayesian Approach for Sequential Probabilistic Back Analysis of Uncertain Geomechanical Parameters and Reliability Updating of Tunneling-Induced Ground Settlements)[J]. Journal of Engineering,2020,:.
  [15]. Science - Science and Engineering; Study Data from Technical University Civil Engineering Bucharest Update Understanding of Science and Engineering (A Nonlinear Model To Analyze the Structures Pounding Forces During Earthquakes)[J]. Journal of Engineering,2020,:.
  [16]. Engineering - Civil Engineering; Study Results from Nanjing Tech University in the Area of Civil Engineering Published (The Characteristics of Seismic Response on Hard Interlayer Sites)[J]. Journal of Engineering,2020,:.
  [17]. Chemicals and Chemistry; Research Data from Department of Civil Engineering Update Understanding of Chemicals and Chemistry (Ceria Doped Cumnox As Carbon Monoxide Oxidation Catalysts: Synthesis and Their Characterization)[J]. Journal of Technology & Science,2020,:.
  [18]. Engineering - Structural and Civil Engineering; Researchers at University of Tehran Have Reported New Data on Structural and Civil Engineering (Semi-active Fuzzy Control of Lali Cable-stayed Bridge Using Mr Dampers Under Seismic Excitation)[J]. News of Science,2020,:.
  [19]田忠喜,汤美安,张保良. 疫情期间土木工程施工线上教学探索与思考[J]. 价值工程,2020,39(20):5-7.
  [20]. Science - Applied Sciences; Researchers from Korea Institute of Civil Engineering and Building Technology Publish New Studies and Findings in the Area of Applied Sciences (Numerical Evaluation of Structural Safety for Aged Onshore Wind Foundation to Extend Service Life)[J]. Science Letter,2020,:.
  [21]. Science - Applied Sciences; Researchers from Beijing University of Civil Engineering and Architecture Report on Findings in Applied Sciences (The Experimental Study on Mechanical Behavior of Conveyor Belt Rubber Bearings)[J]. Science Letter,2020,:.
  [22]. Engineering - Rock Engineering; Data on Rock Engineering Discussed by Researchers at Korea Institute of Civil Engineering and Building Technology (Laboratory True Triaxial Hydraulic Fracturing of Granite Under Six Fluid Injection Schemes and Grain-scale Fracture Observations)[J]. Chemicals & Chemistry,2020,:.
  [23]. Energy - Renewable Energy; Korea Institute of Civil Engineering and Building Technology Researchers Add New Data to Research in Renewable Energy (Study on the Certification Policy of Zero-Energy Buildings in Korea)[J]. Energy Weekly News,2020,:.
  [24]. Engineering - Civil Engineering; Reports from Federal University Rio de Janeiro Add New Data to Findings in Civil Engineering (Workshop for Innovation In the Metrobolises: Urban Mobility Study of a University Campus)[J]. Technology News Focus,2020,:.
  [25]杨晓松,杨保存,黎亮,李宏伟,王荣. 基于区域发展导向的土力学课程教学方法改革[J]. 建材与装饰,2020,(20):126-127.
  [26]覃体事. 土木工程深基坑支护技术及其在房屋建设中的应用[J]. 粘接,2020,43(07):119-121.
  [27]张燕燕. 浅谈绿色建筑材料在土木工程施工中的有效应用[J]. 四川水泥,2020,(07):119-120.
参考文献二
  [28]李进儒. 解读土建施工技术的应用及发展趋势[J]. 四川水泥,2020,(07):271+274.
  [29]高田冰. 计算机模拟仿真技术在土木工程管理中的应用[J]. 中外企业家,2020,(20):118.
  [30]张凤兰. 论工程地质在土木工程建设中的作用[J]. 科技经济导刊,2020,28(20):75.
  [31]汤海鹏. 房屋建筑土木工程施工中的注浆技术分析[J]. 居舍,2020,(20):45-46.
  [32]常小军. 土木建筑工程中注浆施工方法技术探讨[J]. 居舍,2020,(20):63-64.
  [33]胡澄,杨雅鑫,毛瑞勇,吴凤华. 本科生导师制实践探讨——以贵州大学土木类建环专业为例[J]. 教育教学论坛,2020,(29):82-84.
  [34]张祥玉. 项目管理在土木工程建筑施工中的应用[J]. 建材与装饰,2020,(20):136+139.
  [35]孙奇. 土木工程施工中绿色建筑材料的质量检测研究[J]. 建材与装饰,2020,(20):47+51.
  [36]丁点点,樊猛. 基于BIM技术的土木工程专业实践教学改革研究[J]. 教育教学论坛,2020,(29):192-193.
  [37]王德玲,AWUKU SAMUEL KAFUI,沈疆海. 土木工程专业国际本科生毕业设计教学的实践探讨[J]. 教育教学论坛,2020,(29):238-239.
  [38]杨俊雨,刘芳琪,刘慧. 浅析农村土木工程中建筑设计的程序及要求[J]. 现代农业研究,2020,26(07):136-138.
  [39]郭光玲,郭瑞,付江涛. 汉中地区农村房屋抗震性能调查分析研究[J]. 世界地震工程,2020,36(03):93-99.
  [40]杨漩,杨健. 汉画形象的汉代建筑特征研究[J]. 城市建筑,2020,17(20):127-128.
  [41]贾玉勇. 建筑工程大体积混凝土施工技术要点的探讨[J]. 城市建筑,2020,17(20):121-122.
  [42]唐嘉佑,陈玉骥,杨国飞,郭浩宇. 土木工程结构中剪力滞研究综述[J]. 佛山科学技术学院学报(自然科学版),2020,38(04):46-51.
  [43]焦兴苹,范莹莹,才毛,祁晓玲,杨凤梅. 藏药洁白丸(胶囊)质量标准提高研究[J]. 西部中医药,2020,33(07):69-73.
  [44]董岳涛. 土木工程管理施工过程质量控制策略[J]. 陕西建筑,2020,(07):15-17.
  [45]韩健丰,赵高强,魏影. 土木建筑工程施工管理及高层住宅施工[J]. 现代物业(中旬刊),2020,(07):44-45.
  [46]曾西. BIM技术在土木工程施工领域的应用进展[J]. 现代物业(中旬刊),2020,(07):26-27.
  [47]Abbas Solouki,Giovanni Viscomi,Riccardo Lamperti,Piergiorgio Tataranni. Quarry Waste as Precursors in Geopolymers for Civil Engineering Applications: A Decade in Review[J]. Materials,2020,13(14):.
  [48]肖贞林. 不断延伸的研究之路——记华南理工大学土木与交通学院教授符锌砂[J]. 科学中国人,2020,(13):16-23.
  [49]. Engineering - Construction Engineering; Study Results from School of Civil Engineering Provide New Insights into Construction Engineering (An Efficient Approach for Numerical Simulation of Concrete-filled Round-ended Steel Tubes)[J]. Journal of Mathematics,2020,:.
  [50]黎莹,郭秀芹. 应用型本科院校混凝土结构基本原理课程改革探索[J]. 山西建筑,2020,46(14):185-186.
Current Value 3928
Update Date 2020-10-12
