土木导论课参考文献
  以下就是土木毕设网为大家精心整理的土木导论课参考文献50例。供大家学习。
参考文献
  [1]. Coronavirus - COVID-19; Findings from Beijing University of Civil Engineering and Architecture Broaden Understanding of COVID-19 [Risk estimation and prediction of the transmission of coronavirus disease-2019 (COVID-19) in the mainland of China excluding Hubei province][J]. Medical Letter on the CDC & FDA,2020,:.
  [2]. Engineering - Civil Engineering; Report Summarizes Civil Engineering Study Findings from University of Alberta (Arching Followed By Catenary Response of Steel Shear Connections In Disproportionate Collapse)[J]. Journal of Technology & Science,2020,:.
  [3]. Vibration and Acoustics; New Findings Reported from School of Civil Engineering Describe Advances in Vibration and Acoustics (Dynamic Solution for Vehicle-track Interaction Considering the Elastoplasticity of Track Slabs)[J]. Journal of Technology & Science,2020,:.
  [4]. Engineering - Civil Engineering; New Civil Engineering Findings from University of Waterloo Described (Learning-based Image Scale Estimation Using Surface Textures for Quantitative Visual Inspection of Regions-of-interest)[J]. Journal of Technology & Science,2020,:.
  [5]. Engineering - Civil Engineering; Research Data from Atilim University Update Understanding of Civil Engineering (Cost Efficient Design of Mechanically Stabilized Earth Walls Using Adaptive Dimensional Search Algorithm)[J]. Journal of Technology & Science,2020,:.
  [6]. Transportation - Transportation Geotechnics; Studies from Department of Civil Engineering Add New Findings in the Area of Transportation Geotechnics (Geomechanical Characterization of Volcanic Aggregates for Paving Construction Applications and Correlation With the Rock Properties)[J]. Journal of Transportation,2020,:.
  [7]. Transportation Research; Investigators at Department of Civil and Environmental Engineering Discuss Findings in Transportation Research (Improving Durability of Asphalt Pavements In Louisiana Through Increased In-place Field Density)[J]. Journal of Transportation,2020,:.
  [8]. Geomechanics; Studies from Department of Civil Engineering in the Area of Geomechanics Reported (Estimation of Transient Forces In Single Pile Embedded In Liquefiable Soil)[J]. Science Letter,2020,:.
  [9]. Geomechanics; Reports from School of Civil Engineering Add New Data to Findings in Geomechanics (Numerical Investigation of the Elastic Properties of Binary Mixtures As a Function of the Size Ratio and Fines Content)[J]. Science Letter,2020,:.
  [10]. Science - Science and Engineering; Investigators from Department of Civil Engineering Target Science and Engineering (Influence of Chloroprene Rubber Latex On Set Times and Early Hydration of Cement)[J]. Chemicals & Chemistry,2020,:.
  [11]. Engineering - Civil Engineering; New Civil Engineering Study Findings Recently Were Published by Researchers at Changsha University of Science & Technology (Preparation and Performance Characterization of Warm-Mix Rejuvenated Bioasphalt)[J]. Chemicals & Chemistry,2020,:.
  [12]. Environment; Studies from Civil Engineering Department Provide New Data on Environment (Mechanical Properties and Mix Design of Geopolymer concrete - A review)[J]. Ecology Environment & Conservation,2020,:.
  [13]. Environment; Studies from Department of Civil Engineering Add New Findings in the Area of Environment (Effect of basalt fibre on the mechanical properties of M70 grade high performance concrete)[J]. Ecology Environment & Conservation,2020,:.
  [14]. Environmental Pollution; Reports from School of Civil and Environmental Engineering Provide New Insights into Environmental Pollution (Spatial and vertical distribution, composition profiles, sources, and ecological risk assessment of polycyclic aromatic hydrocarbon ...)[J]. Ecology Environment & Conservation,2020,:.
  [15]. Environment; Research from Department of Civil Engineering Reveals New Findings on Environment (Experimental Investigation on Foam Concrete With Partial Replacement of Fine Aggreate By Fly Ash And Cement By Alccofine)[J]. Ecology Environment & Conservation,2020,:.
  [16]. Environment; Research on Environment Detailed by Researchers at Department of Civil Engineering (Effect of Manufactured Sand on Flexural Behavior of Geopolymer RCC Beams: A review)[J]. Ecology Environment & Conservation,2020,:.
  [17]. Environment; Recent Findings from Department of Civil Engineering Highlight Research in Environment (Behavior of Monotonic Loading for Glass Fibre based High Performance Concrete in External Beam-Column Joint using ANSYS. Analysis)[J]. Ecology Environment & Conservation,2020,:.
  [18]. Environment; Researchers from Department of Civil Engineering Report Recent Findings in Environment (A Review on Geopolymer RCC Beams made with Recycled Coarse Aggregate)[J]. Ecology Environment & Conservation,2020,:.
  [19]. Environment; Researchers at Department of Civil Engineering Zero in on Environment (Experimental Investigation on Workability and Density of Medium-Range Foam Concrete with Hybrid Fibers)[J]. Ecology Environment & Conservation,2020,:.
  [20]. Environmental Research; Reports from School of Civil Engineering Add New Data to Findings in Environmental Research (Study On Vegetation Concrete Technology for Slope Protection and Greening Engineering)[J]. Ecology Environment & Conservation,2020,:.
  [21]. Environment; New Environment Research from Department of Civil Engineering Discussed (Effect of Recycled Aggregates on Strength and performance of Recylced Aggregate Concrete)[J]. Ecology Environment & Conservation,2020,:.
  [22]. Environment; Findings in Environment Reported from Civil Engineering Department (Effect of Review elevated temperature on geo-polymer concrete - A Review)[J]. Ecology Environment & Conservation,2020,:.
  [23]. Environment; Data from Department of Civil Engineering Provide New Insights into Environment (Model Study of Decision Support System for Water Management)[J]. Ecology Environment & Conservation,2020,:.
  [24]. Environment; Civil Engineering Department Researchers Release New Data on Environment (Effect of Durability properties on Geopolymer concrete - A Review)[J]. Ecology Environment & Conservation,2020,:.
  [25]. Environment; Department of Civil Engineering Researchers Update Current Data on Environment (A Review of mathematical models for prediction of Stress-strain and moment -curvature behaviour in concrete)[J]. Ecology Environment & Conservation,2020,:.
  [26]. Earth Systems Modelling; Department of Civil Engineering Researchers Describe Advances in Earth Systems Modelling (Development and Verification of a Three-Dimensional Variably Saturated Flow Model for Assessment of Future Global Water Resources)[J]. Ecology Environment & Conservation,2020,:.
  [27]. Energy - Wind Farms; Department of Civil Engineering Researchers Provide New Study Findings on Wind Farms (Foundation Types for Land and Offshore Sustainable Wind Energy Turbine Towers)[J]. Energy Weekly News,2020,:.
  [28]. Conservation Research; Studies Conducted at School of Civil Engineering on Conservation Research Recently Reported (Incorporation of Disposed Oil-contaminated Soil In Cement-based Materials)[J]. Energy & Ecology,2020,:.
  [29]ShiHu Tong. Research on The Application of Deep Foundation Pit Support Construction Technology in Civil Engineering[J]. International Journal of Education and Economics,2020,3(3):.
  [30]Yasin Onuralp ?zk?l??, Emrah Madenci, Lokman Gemi. Tensile and Compressive Behaviors of the Pultruded Gfrp Lamina[J]. Turkish Journal of Engineering,2020,4(4):.
  [31]张靖宇. 土木工程建筑结构中存在的问题及对策[J]. 砖瓦,2020,(09):82-83.
  [32]华夏. 土木工程材料在绿色建筑中的应用[J]. 砖瓦,2020,(09):90+92.
  [33]梁俊. 探讨土木工程施工中的裂缝处理[J]. 砖瓦,2020,(09):129+131.
  [34]苏泽强. 土木工程施工技术中BIM技术应用的有效性探究[J]. 砖瓦,2020,(09):148-149.
  [35]游奇龙. 土木工程施工中节能绿色环保技术研究[J]. 砖瓦,2020,(09):183+185.
  [36]刘洪宇,谢志英. BIM技术在工程实际中的优势[J]. 四川建材,2020,46(09):43-44.
  [37]高乐,刘玲华,王璐. 基于云班课平台的混合式教学模式实践探索——以独立学院钢筋混凝土基本原理课程为例[J]. 四川建材,2020,46(09):225-226+228.
  [38]Zhang Jun,Yu Jia,Guan Tao,Wang Jiajun,Tong Dawei,Wu Binping. Adaptive Compaction Construction Simulation Based on Bayesian Field Theory.[J]. Sensors (Basel, Switzerland),2020,20(18):.
  [39]Alan Powderham,Anthony O'Brien. The Observational Method in Civil Engineering:Minimising Risk, Maximising Economy[M].CRC Press:2020-09-10.
  [40]Airong Chen,Xin Ruan,Dan M. Frangopol. Life-Cycle Civil Engineering: Innovation, Theory and Practice:Proceedings of the 7th International Symposium on Life-Cycle Civil Engineering (IALCCE 2020), October 27-30, 2020, Shanghai, China[M].CRC Press:2020-09-10.
  [41]. Environmental Research; Reports from Beijing University of Civil Engineering and Architecture Add New Data to Findings in Environmental Research (Simultaneous removal of bioaerosols, odors and volatile organic compounds from a wastewater treatment plant by a ...)[J]. Biotech Week,2020,:.
  [42]. Geotechnics; Reports on Geotechnics from School of Civil Engineering Provide New Insights (Seismic Active Earth Pressure of Unsaturated Soils With a Crack Using Pseudo-dynamic Approach)[J]. Computer Weekly News,2020,:.
  [43]沈之容. 高等结构试验课程钢结构现场无损检测试验教学改革探讨[J]. 教育教学论坛,2020,(37):135-137.
  [44]陈垚,袁绍春,蒋彬. 基于职业导向的土木水利全日制专业学位研究生的培养探索——以城市水务与水环境专业领域为例[J]. 教育教学论坛,2020,(37):190-191.[1]. Coronavirus - COVID-19; Findings from Beijing University of Civil Engineering and Architecture Broaden Understanding of COVID-19 [Risk estimation and prediction of the transmission of coronavirus disease-2019 (COVID-19) in the mainland of China excluding Hubei province][J]. Medical Letter on the CDC & FDA,2020,:.
参考文献二
  [45]. 中联重科桩工20台大型旋挖钻机交付  携手战略合作伙伴共赢共创[J]. 建筑机械,2020,(09):40.
  [46]郝俊杰. 模板施工技术在土建工程施工中的应用[J]. 四川水泥,2020,(09):56+60.
  [47]陈淑静. 土木工程建筑施工技术创新研究[J]. 四川水泥,2020,(09):168+170.
  [48]张成瑞. 项目管理在土木工程建筑施工中的运用研究[J]. 绿色环保建材,2020,(09):131-132.
  [49]连梦仪. 基于BIM技术的土木工程专业实践教学应用研究[J]. 绿色环保建材,2020,(09):139-140.
  [50]刘超. 土木工程施工节能绿色环保技术研究[J]. 绿色环保建材,2020,(09):70-71.
Current Value 4841
Update Date 2020-10-15
