[建筑结构设计文档] 某中学5层教学楼建筑结构设计+施工组织设计
摘  要
濮阳职中教学楼是一个框架结构的多层建筑。本设计总共分为建筑设计和结构设计两部分。其中建筑设计部分包括平面、立面、剖面的设计。结构设计部分主要做了一榀横向框架的结构计算与设计。该职中教学楼为五层钢筋混凝土框架结构体系,是为学校教师及学生提供各种教学,实验,会议等服务的场所。总建筑面积为2970m2。在进行建筑设计的过程中,在满足其使用功能的前提下,我还努力满足其安全、经济、美观等方面的要求。并且,在进行建筑设计时,也考虑到一些结构上的布置,使二者相辅相成。更重要的是,所有的设计均是在符合规范的前提下进行的。 即在选定了结构体系,确定了计算简图后,通过计算出水平力与竖向力,得出作用在结构上的内力。然后加上地震力可以进行内力组合,找出最不利内力,并对截面进行配筋设计。特别要注意的是,在计算时各方面要符合有关规范的要求,截面的配筋同时要满足构造要求。此外,在结构设计最后还进行了一个柱下独立基础、一部楼梯及一块现浇板的设计与计算。
关键词:框架结构 ;  平面设计  ; 立面设计  ; 剖面设计
Puyang vocational school building is a frame structure of the multi-storey buildings. The design is divided into building design and structural design in two parts. One part of building design, including plan, elevation, profile design. Design part is mainly made of a Pin horizontal frame structure calculation and design. Teaching Building of the post in the five-story reinforced concrete frame structure for the system is for school teachers and students a variety of teaching, laboratory, meeting place and other services. The total construction area of 2970m2. During the architectural design process, to meet the use function of the premise, I also strive to meet the security, economic, aesthetic and other requirements. And, during the building design, but also consider some of the structural arrangement, so the two complement each other. More importantly, all the design specifications are subject to the premise. Structural system that is selected to determine the calculation diagram, the horizontal force by calculating the vertical force and obtained the internal forces acting on the structure. And internal forces with seismic force can be combined to identify the most unfavorable internal forces, and cross-section of reinforcement design. To note that in all aspects of the calculation specifications to comply with the requirements of both sections of the reinforcement structure to meet the requirements. In addition, the structural design and finally to a single foundation under column, a staircase and a piece of design and calculation of Slab.
Key Words: Frame structure;  graphic design;  facade design;  profile design
建筑结构毕业设计文档-某中学5层教学楼建筑结构设计+施工组织设计(1) 某中学5层教学楼建筑结构设计 施工组织设计.pdf (889.38 KB, 下载次数: 4)
满意就快下载吧,纯word格式
Current Value 11392
Update Date 2015-11-17
