某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600]
中文摘要
关键词:综合楼,建筑物,结构。
我这次设计的课题为某综合楼。为六层框架结构,总高度23.4m,建筑面积5600m2。设计分为建筑设计和结构设计两部分。这是我第一次在老师指导下将整栋大楼从建筑到结构完整、全面地设计出来。
一、建筑设计
在满足设计任务书提出的功能要求前提下,进行平面布置、立面造型布置及剖面设计,最后绘出建筑图。
二、结构设计
    大概分为七个部分:
1、确定构件的几何尺寸,选择计算框架;
2、计算水平荷载(地震、风载)作用下的梁柱内力;
3、计算竖向荷载(恒载、活载)作用下的梁柱内力;
4、内力调幅与换算
5、内力组合
6、根据内力组合中几种最不利的组合情况,进行柱、梁、楼梯、板、基础的配筋计算;
7、根据结构计算,绘制施工图。
这次毕业设计使我系统、全面地复习了以前所学的专业知识,更掌握了许多以前所不了解的新知识。但在设计、计算过程中,一定还存在很多不足之处,恳请老师加以指正。
The abstract
Key Words: the synthesizing building, construction, frame.
The graduation project that I this time design is the synthesizing building which is a construction of six frames. It is 23.4m highly and its area is 5600 square meters. It is my first time that I design the entire building from the construction to the frame with the teacher's guidance.
This design involves the construction design and the frame design.
First, the construction design:
At the satisfy to function request that proposed in taskbar, I proceed the good plane arrangement, the standing shape arrangement and the section designs, finally I draw the building drawings.
Second, the frame design:
The frame design is divided into seven parts.
1.Determine the geometric parameter and mechanics parameter of the components, and select the right frame.
2. Calculate the perpendicular load (Dead loads and Live loads).
3. Calculate the horizontal load (The earthquake loads the wind loads).
4. Chang and adjust the internal force.
5. Compose the internal force of the structure (Beam and Column)
6. Add the reinforcing steel to the pillar, the beam, the board, the staircase and the foundation according to the most harmful combine of internal force.
7. According to the steps of the structural calculation draw the structure drawings.
For this design project for graduation I reviewed all I’d learned systematically and overlay. I grasped that I hadn’t known before. But there are many mistakes, so I hope the teachers can point out them and correct them.
建筑面积:5600m2
建筑层数:6层
建筑高度:23.4m
建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](1) 计算书.pdf (4.22 MB, 下载次数: 10, 售价: 1 积分)
建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](2) 建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](3) 建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](4) 建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](5)
建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](6) 建筑结构毕业设计-某地6层框架结构综合楼建筑结构设计(计算书+图纸)[面积5600](7)
Current Value 11818
Update Date 2015-11-29
