[水利水电毕业设计] 某县山区水电站工程油气水系统毕业设计(设计书+图纸)
商县二龙山水电站工程油气水系统设计
摘 要:
水电站除了拥有水力机组及其附属设备之外,还应有保证机组安全、经济运行的辅助设备,这些辅助设备包括油的供应与维护系统、压缩空气系统、技术供水系统、排水系统、水力检测系统以及某些水电站装设的水轮机进水阀等,这些辅助设备虽然不能直接产生电能,但对保证电站和水利机组安全经济运行有着决定性的作用,所以辅助设备设计是水电站整体设计的一个重要的组成部分。本设计根据二龙山水电站水轮机(型号为HL230-LJ-100)和发电机(型号为TSL215/36-16)特性,结合二龙山水电站工程特点及厂房实际布置情况,进行二龙山水电站油气水系统设计。在油系统设计中根据油系统的任务和用油要求选择油种类,计算油量,选择贮油设备、净油设备和输油管道,绘制系统图和布置图。气系统设计中进行了低压气系统设计,根据用气对象选择低压气系统设备和管道,绘制系统图和布置图。水统设计中进行了技术供水系统设计,消防供水系统设计,生活供水系统设计和排水系统设计,为各设计部分绘制系统图和布置图。
关键词:水电站;油系统;水系统;气系统
ShangXianErLongShan Hydropower Project Oil,Gas and Water System
Abstract:In addition to hydropower stations and its subsidiary units have hydraulic equipment, the unit should be guaranteed security, economic operation of auxiliary equipment, such auxiliary equipment, including oil supply and maintenance system, compressed air systems, technology water supply systems, drainage systems, water detection system And some hydropower stations installed into the turbine valves, etc., these aids can not directly generate electricity, but ensure that power stations and water safety unit of economic operation has a decisive role, auxiliary equipment design the overall design of the hydropower station is an important group A part of. According to the design of the turbine Erlongshan Hydropower Station (Model for HL230-LJ-100) and generator (model for TSL215/36-16) characteristics, combining features of Erlongshan Hydropower Project and the actual plant layout, a hydropower station in Erlongshan oil and gas water system design . In the oil system designed in accordance with the mandate of the oil system and oil asked to select types of oil, calculated oil, the choice of oil storage facilities, equipment and Absolute Oil pipeline mapping system map and layout. Gas system design for a low-pressure gas system design, according to choose targets of low-pressure gas equipment and gas pipeline systems, mapping systems and layout plans. Water Commission in the design of a water supply system design technology, fire water supply system design, system design life of the water supply and drainage system design, drawing for the design of the system map and layout.
Key words: Hydropower Station;oil system; water system; gas system
目 录
摘 要:        1
第一章 前言        3
1.1设计的目的和意义        3
1.2工程概况        3
第二章 油系统设计        5
2.1 油系统的任务和组成        5
2.1.1油系统的任务        5
2.1.2油系统的组成        5
2.2油系统的计算、设备选择及系统图设计        5
2.2.1用油量的估算        5
2.2.2油系统设备的选择        6
2.3 油系统的布置及防火要求        6
2.3.1油系统的布置        6
2.3.2油系统的防火安全要求        7
第三章 气系统设计        8
3.1 概述        8
3.2低压气系统的供气对象        8
3.3低压气系统设备选取        8
3.3.1低压空气系统设备的选取        8
3.3.2低压气系统管路附件及其他设备选取        11
3.4低压空气系统图        11
3.5低压气系统设备管路布置        11
3.6低压气系统机械操作        11
3.6.1空压机运行操作        11
3.6.2机组制动用气操作        12
第四章 供水系统设计        14
4.1技术供水系统        14
4.1.1技术供水对象        14
4.1.2技术供水的基本要求        14
4.2消防供水系统        17
4.3生活供水系统        18
4.4供水系统管径选择与水力计算        18
第五章 排水系统        21
5.1排水系统的分类和排水方式        21
5.2排水系统的设计与布置        21
5.3排水系统的机械操作        25
5.3.1自动操作        25
5.3.2备用水泵工作        25
5.3.2手动操作        25
参考文献        26
附录        27
致谢        31
部分内容展示
Current Value 12469
Update Date 2016-11-12
