白沙水库位于淮河流域沙颖河上游,坝址位于河南省禹州市与登封市交界的白沙村以北300m处。,水库控制流域面积为985km2,占颖河流域面积7230km2的13.6%,占颖河山丘区流域面积1900km2的51.8%,是以防洪灌溉为主,兼顾工业供水、水产养殖、旅游等综合利用的大型枢纽工程。白沙水库总库容2.78亿m3,,按国标《防洪标准》规定,白沙水库工程等别应为大(2)型,泄洪闸为2级建筑物. 泄洪闸设计标准为100年一遇,校核标准为2000年一遇。据《溢洪道设计规范》(SL253—2000)闸下防冲设计标准按50年一遇,校核标准100年一遇。
本次设计是白沙水库除险加固工程中的溢洪道设计.其中包括以下几个方面内容:方案的比较和选择以及水力计算,结构稳定性计算(包括边墩,中墩和挡土墙稳定基底应力计算),简单的施工组织设计等几个方面
关键词: 溢洪道 中墩 水库 结构稳定性
The Baisha reservoir is located upstream of Huaihe River basin Sha Yinghe, the dam site is located the Henan Province Yuzhou and the Dengfeng city border Baisha village by northern 300m place. The reservoir control drainage area is 985km2, occupies Ying river drainage area 7230km2 13.6%, occupies Ying river massif area drainage area 1900km2 51.8%, is by prevents floods and the irrigation primarily, proper attention to both industrial water supply, aquaculture, traveling large and so on comprehensive utilization large -scale key project. Baisha reservoir total storage capacity 278 million m3, "Flood prevention Standard" stipulated according to GB code, The Baisha reservoir project bank should be is big (2), The floodgate is 2 levels of buildings, the floodgate design standard is 100 years as soon as meets, The examination standard is in 2000 as soon as meets. According to "Spillway Design Standard" (SL253 -2000) under the floodgate the design standard of Disappearing energy and guarding against flushes meet according to 50 years, The examination standard meet as soon as 100 years.
This design is the Baisha reservoir except dangerous reinforcement project in spillway design, including following several aspects content: Plan comparison and choice as well as water power computation, structural stability computation including side pillar,center pillar and bulkhead stable basis stress computation, simple construction organization plan and so on several aspects
Key word: spillway center pillar reservoir structural stability
前言
白沙水库位于淮河流域沙颖河上游,坝址位于河南省禹州市与登封市交界的白沙村以北300m处。是50年代初治淮早期我省兴建的大型水库之一,当时水库的设计洪水标准为100年一遇,校核洪水标准为1000年一遇。设计水位233.8m,校核水位235.3m,总库容2.95亿m3。水库控制流域面积为985km2,占颖河流域面积7230km2的13.6%,占颖河山丘区流域面积1900km2的51.8%,是以防洪灌溉为主兼顾工业供水、水产养殖、旅游等综合利用的大型枢纽工程本次设计主要是白沙水库加固工程中溢洪道泄洪闸白沙水库是建国初期治淮第一批兴建的大(II)型水库,是以防洪灌溉为主,兼顾工业供水、水产养殖、旅游等综合利用的大型水利枢纽工程。
白沙水库目前的现状为坝顶高程235.8m,防浪墙顶高程237.0m,坝顶超高1.873m,水库现状允许最高水位为235.13m。
1951年3月开始施工至1953年8月建成,为此于1956年2月~1957年12月进行了水库扩建,扩建后的大坝坝顶长1316m,顶宽6.6m,最大坝高47.88m,坝型由均质土坝变为复式断面,坝顶高程235.8m,防浪墙顶高程237.0m。改原无控制的溢洪道为新建8孔(12×8)弧形钢闸门控制的泄洪闸,闸顶高程225.92m,最大泄量4280 m3/s。1975年汛后,为增强水库抗洪能力,在东付坝坝顶建爆破药室17个,以应急需。
1997年底又对输水洞进行了较全面的加固处理。在出口新建了弧形工作门及引水岔管,输水洞由无压隧洞改为压力洞,洞身由马蹄形断面改为直径3.3m的圆形断面。
工程存在的问题
(1)泄洪闸上下游流态不好。
(2)泄洪闸闸室建在强风化的石英砂岩地基上,并且有断层。
(3)闸墩单薄,砼质量不好,碳化严重,普遍存在裂缝。
(4)溢洪道没有尾水渠,不能做正常溢洪道使用。
(5)溢洪道闸门启闭机和闸们年久失修。
主溢洪道:泄洪闸座落在强风化石英砂岩上,裂隙发育,岩体呈中等至强透水,工程地质条件差,存在闸基渗漏、抗滑稳定和不均匀沉陷问题,应对闸基稳定性进行复核,并采取必要的处理措施。
本次设计是白沙水库除险加固工程中的溢洪道设计.其中包括以下几个方面内容:方案的比较和选择以及水力计算,结构稳定性计算(包括边墩,中墩和挡土墙稳定基底应力计算),简单的施工组织设计等几个方面。
参照《溢洪道设计规范》(SL253—2000)附录A,泄洪闸闸室采用开敞式实用堰结构,堰顶上游采用三圆弧曲线,堰顶下游采用WES型幂曲线,幂曲线末端直接与反弧连接,根据水力计算确定工程的布置,然后进行稳定性和应力计算。
部分内容展示
