建筑面积:6203m2
建筑层数:3层
建筑高度:14.0m
文件内容:计算书+图纸+工程量计算书
本工程名称为长沙望城区农民新村农民之家活动中心设计,结构为现浇混凝土框架结构,3层,建筑面积为6023.96平方米,设计使用年限为50年。工程所在地区为长沙市望城区,抗震设防烈度为7度,设计过程遵循先建筑后结构再施工的顺序进行。
建筑设计,依据建筑总体规划要求、建筑用地条件和基地周边的环境特点,首先进行建筑平面设计,其次进行剖面和立面设计。考虑到建筑等级和防火要求,建筑设计应满足使用功能和造型艺术的要求,并适应未来发展与灵活改造的需要。
结构设计主要包括结构选型及结构布置(本工程采用钢筋混凝土框架结构体系),确定计算简图,选择具有代表性的一榀框架进行荷载计算、侧移控制、内力组合、框架梁柱配筋计算、基础设计、楼梯设计等。对于竖向荷载作用,采用分层法计算,水平荷载作用反弯点法计算。
施工图预算包括工程量清单和投标总价的分析计算。
关键词:活动中心;建筑设计;结构设计;工程造价
This project is designed for the new village activity center in Wangcheng with a style of cast-in frame work. The building has three floors. The structure locates in Hunan, Changsha,Wangcheng, where the seismic fortification intensity is 7 degrees. The design process follows the order: firstly, the architectural design; secondly, the structural design; lastly, the foundation design. The architectural design is according to the master plan of the building, the site conditions, the peripheral urban environment, and the characteristic of the base.
Actually, the building plain design goes first. The elevation design is carried out secondly. Considering the building classification and fire prevention demands, the architectural design should meet the needs of the function requirement, the use requirement and the development in the future.
Structural design maintains close ties with the architectural design, which is based on current relevant codes. It includes the structure style, the preliminary estimation for the structural members, the confirmation of the sketch and unit for calculation, the sideway control, the load calculation, the component design, the slab-stairs design, the floor overlay design, the foundation design. This project adopts reinforced concrete frame (transverse bearing), which has chosen a representative frame to calculate. Vertical load function adopts moment distribution method, and level load function adopts the inflection point method, and seismic load function adopts equivalent base shear method. During the design process earthquake-resistant design, technical economy index and construction industrialized request are synthetically considered.
The construction budget includes analysis and calculation of the bill of quantities and the total bid.
Key words:Activity center; Architectural design; Structural design; Budget
计算书.pdf
(1.7 MB, 下载次数: 3)
工程量预算计算书.pdf
(216.39 KB, 下载次数: 0)
