This thesis tell the design processes of a residential building in the national garden of Guan shan。It is six -layer reinforced concrete frame. It has six stories, the height of the first storey is 4.05 meters, and the height of other stories are all 2.8 meters. The height of the whole building is 18.4 meters.
The teaching building belong to public buildings of civil building, in design of calculating consulting more relevant booKlists, and finished according to the design specification of the building strictly. This design is divided into two major parts mainly:
The first part is the architectural design。The architectural design is on the premise of master plan, according to the request of tasK booK, considering the base environment synthetically, the function of use, the structure constructs, material equipment, architectural design and artistic question of the building , solve the function of use of the building and arrangement in the space. Whether according to concept design of building, principle policy of building,the design should finish the following aspects. The overall arrangement of the building , the elementary cell is designed, the public part is designed, the space is made up and designed, the roofing is designed, the elevation design of the building and building fire prevention and design etc..
The second part is structural design. Structural design is consisted by calculation of wind load ,design of frame, stair design, board design with the foundation designing etc. maKing up. Should build provide fortification against earthquaKes earthquaKe intensity 7 , antidetonation grade for being tertiary , consider horizontal earthquaKe function impact on horizontal frame and apply the method of for force calculate ,Vertical to load function, horizontal frame internal force calculate and adopt the method of to assign France, and internal force maKe up vertical to is it maKe up and not vertical to load with earthquaKe strength setting a roof beam in place to frame
Keywords: reinforced concrete, frame, the design of the structure
