施工组织设计国外文献
  以下是土木毕设网小编为大家搜集整理的施工组织设计国外文献,供大家参考和借鉴!更多内容尽在参考文献栏目!
参考文献
  [1]刘飞虎. 基于BIM的施工组织辅助决策系统的研发及应用[A]. 中国图学学会土木工程图学分会.第六届BIM技术国际交流会——数字建造在地产、设计、施工领域应用与发展论文集[C].中国图学学会土木工程图学分会:《土木建筑工程信息技术》编辑部,2019:4.
  [2]Erica M. Comber,Rachelle N. Palchesko,Wai Hoe NG,Xi Ren,Keith E. Cook. De novo lung biofabrication: clinical need, construction methods, and design strategy[J]. Translational Research,2019,211:.
  [3]Xu Li,Dong Xu,Wei Wang,Peng Lin,Huiming Liu,Arata Nishimura,Fuzhi Shen,Laifeng Li. Design and construction of a 1.8 K superfluid 4 He system with a G-M cryocooler[J]. Cryogenics,2019,102:.
  [4]Xianfeng Meng,Shenhui Dong. Design and construction of lightweight C/Co heterojunction nanofibres for enhanced microwave absorption performance[J]. Journal of Alloys and Compounds,2019,810:.
  [5]Wenjie Zhou,Wen Nie,Changqi Liu,Qiang Liu,Wang Hetang,Cunhou Wei,Jiayi Yan,Shuai Yin,Zihao Xiu,Changwei Xu. Modelling of ventilation and dust control effects during tunnel construction[J]. International Journal of Mechanical Sciences,2019,160:.
  [6]Mahmoud A. El-Emam,Saad Fathallah Ahmed,Mohamed Ahmed Sabah,Soliman Nasif,Shi W. Dong,Ling Zhou. Design and construction of a pneumatic harvesting and cleaning machine for jojoba seeds[J]. Engineering in Agriculture, Environment and Food,2019,:.
  [7]Fáver Gómez-Narváez,Santiago Gómez-Narváez,José Contreras-Calderón,Julián Builes-Rivera,Angela Pérez-Martínez. Design and construction of a thin-film drying channel equipment - Modeling the drying kinetics of nanofiltered whey[J]. Journal of Food Engineering,2019,263:.
  [8]Xiaoling Song,Feniosky Pe?a-Mora,Charles Shen,Zhe Zhang,Jiuping Xu. Modelling the effect of multi-stakeholder interactions on construction site layout planning using agent-based decentralized optimization[J]. Automation in Construction,2019,107:.
  [9]Taixiu Liu,Zhang Bai,Zhimei Zheng,Qibin Liu,Jing Lei,Jun Sui,Hongguang Jin. 100 kW e power generation pilot plant with a solar thermochemical process: design, modeling, construction, and testing[J]. Applied Energy,2019,251:.
  [10]Tsuyoshi Seike,Takayuki Isobe,Yusuke Hosaka,Yongsun Kim,Shiro Watanabe,Maito Shimura. Design and Supply System for Emergency Temporary Housing by Various Construction Methods from the Perspective of Environmental Impact Assessment: The Case for the Great East Japan Earthquake[J]. Energy & Buildings,2019,:.
  [11]M. Takechi,S. Sakurai,K. Masaki,G. Matsunaga,A. Sakasai. Disruption simulations for JT-60SA design and construction[J]. Fusion Engineering and Design,2019,146(Pt B):.
  [12]M.E. Emetere,T. Osunlola,G. Otoko. Design and Construction of Fruit Solar Drier[J]. Procedia Manufacturing,2019,35:.
  [13]Huan Liu,Jinfei Niu,Xiaodong Wang,Dezhen Wu. Design and construction of mesoporous silica/ n -eicosane phase-change nanocomposites for supercooling depression and heat transfer enhancement[J]. Energy,2019,188:.
  [14]Dylan Hardison,Matthew Hallowell,Ray Littlejohn. Does the format of design information affect hazard recognition performance in construction hazard prevention through design reviews?[J]. Safety Science,2020,121:.
  [15]Vladimir J. Alzamora Guzmán,Julie A. Glasscock,Ferris Whitehouse. Design and construction of an off-grid gravitational vortex hydropower plant: A case study in rural Peru[J]. Sustainable Energy Technologies and Assessments,2019,35:.
  [16]Patrick Rieck. Design, construction and test of small-diameter Muon Drift Tube chambers (sMDT) for the Phase-1 upgrade of the ATLAS muon spectrometer[J]. Nuclear Inst. and Methods in Physics Research, A,2019,:.
  [17]Reza Mahmoudi,Seyyed-Nader Shetab-Boushehri,Seyed Reza Hejazi,Ali Emrouznejad,Parisa Rajabi. A hybrid egalitarian bargaining game-DEA and sustainable network design approach for evaluating, selecting and scheduling urban road construction projects[J]. Transportation Research Part E,2019,130:.
  [18]Zhangxun Xia,Xiaoming Zhang,Hai Sun,Suli Wang,Gongquan Sun. Recent advances in multi-scale design and construction of materials for direct methanol fuel cells[J]. Nano Energy,2019,65:.
  [19]Yue Wu,Xiuming Liu,Boxuan Chen,Qingpeng Li,Peng Luo,Arno Pronk. Design, construction and monitoring of an ice composite shell structure[J]. Automation in Construction,2019,106:.
  [20]Bernd Heinrich,Felix Krause,Alexander Schiller. Automated planning of process models: The construction of parallel splits and synchronizations[J]. Decision Support Systems,2019,125:.
  [21]Yueh-Cheng Wu,Sheng-Wei Lin,Yi-Han Wang. Cultural tourism and temples: Content construction and interactivity design[J]. Tourism Management,2020,76:.
  [22]Nuray Y?lmaz Baran,Talat Baran,Ayfer Mente?. Design of highly robust halloysite nanoclay supported palladium complex as a highly active heterogeneous catalyst for construction of biaryls[J]. Applied Clay Science,2019,181:.
  [23]Wanida Limmun,Boonorm Chomtee,John J. Borkowski. The construction of robust mixture‐process experimental designs via genetic algorithm[J]. Quality and Reliability Engineering International,2019,35(6):.
  [24]Jesper Pihl. Design and construction of the H?logaland Bridge[J]. ce/papers,2019,3(3-4):.
  [25]Yaquelin V. Pantoja,Armando J. Ríos,Moisés Tapia Esquivias. A method for construction of mixed‐level fractional designs[J]. Quality and Reliability Engineering International,2019,35(6):.
  [26]Comber Erica M,Palchesko Rachelle N,Ng Wai Hoe,Ren Xi,Cook Keith E. De novo lung biofabrication: clinical need, construction methods, and design strategy.[J]. Translational research : the journal of laboratory and clinical medicine,2019,211:.
  [27]Fields Gregg B. Methods for the Construction of Collagen-Based Triple-Helical Peptides Designed as Matrix Metalloproteinase Inhibitors.[J]. Methods in molecular biology (Clifton, N.J.),2019,1944:.
  [28]Chen Lu,Gao Zhishan,Ye Jingfei,Cao Xin,Xu Ningyan,Yuan Qun. Construction method through multiple off-axis parabolic surfaces expansion and mixing to design an easy-aligned freeform spectrometer.[J]. Optics express,2019,27(18):.
  [29]Mascini Marcello,Dikici Emre,Robles Ma?ueco Marta,Perez-Erviti Julio A,Deo Sapna K,Compagnone Dario,Wang Joseph,Pingarrón José M,Daunert Sylvia. Computationally Designed Peptides for Zika Virus Detection: An Incremental Construction Approach.[J]. Biomolecules,2019,9(9):.
  [30]Campsie Paul,Childs Peter G,Robertson Shaun N,Cameron Kenny,Hough James,Salmeron-Sanchez Manuel,Tsimbouri Penelope M,Vichare Parag,Dalby Matthew J,Reid Stuart. Design, construction and characterisation of a novel nanovibrational bioreactor and cultureware for osteogenesis.[J]. Scientific reports,2019,9(1):.
参考文献二
  [31]Wang Li,Xu Xun,Cheng Qunfeng,Dou Shi Xue,Du Yi. Near-Infrared-Driven Photocatalysts: Design, Construction, and Applications.[J]. Small (Weinheim an der Bergstrasse, Germany),2019,:.
  [32]朱贵民. 基于引嫩扩建富裕县灌区监理如何控制好工程的质量[J]. 科技创新与应用,2019,(25):185-186.
  [33]鲁向坤. 南水北调中线某工程段施工导流设计[J]. 科技创新与应用,2019,(25):91-92.
  [34]范文静. 水利工程施工技术和质量提升策略研究[J]. 工程技术研究,2019,4(16):154-155.
  [35]刘阳辉,朱杰. 园林施工及养护管理的特点与有效措施[J]. 现代园艺,2019,42(17):194-195.
  [36]范圣健. 大跨度球面结构双曲吊顶铝面板安装技术[J]. 科技风,2019,(26):143.
  [37]吴赞平,金明新. 《高速公路养护工程施工安全技术规程》修订综述[J]. 现代交通技术,2019,16(04):7-11.
  [38]闫红利. 化二东侧路(化工路~广渠路)道路工程施工组织设计施工方案[J]. 中国住宅设施,2019,(08):61-62+15.
  [39]尚路光. 火力发电厂电气控制设备安装施工质量控制探讨[J]. 科学技术创新,2019,(25):33-34.
  [40]尚路光. 火力发电厂电气控制设备安装施工质量控制探讨[J]. 科学技术创新,2019,(25):33-34.
  [41]丁彦,田元福. 装配式建筑施工质量与安全风险评价研究[J]. 建筑经济,2019,(09):80-84.
  [42]郑淼. 航道疏浚工程常见问题及治理措施[J]. 技术与市场,2019,(09):158.
  [43]. Building and Construction; Researchers from Department of Construction Engineering Report Recent Findings in Building and Construction (Link Between Different Bottom-up Fatigue's Law Coefficients of Mechanical-empirical Pavement Design Software)[J]. Computers, Networks & Communications,2019,:.
  [44]Leslie Baz, Computational BIM Specialist. The balancing act: Efficiency and beauty in design and construction[J]. Building Design & Construction,2019,:.
  [45]Phil Rice,Richard Flanagan,Mohammed Nasim. Design and construction procurement for the Amtrak Hudson Tunnel project[J]. Mining Engineering,2019,71(9):.
  [46]. Peri GmbH; Patent Issued for Method Of Planning Scaffolding For Construction Of An Industrial Plant (USPTO 10,385,575)[J]. Computers, Networks & Communications,2019,:.
  [47]Shuo Cui. Research on the Integration and Construction Design Strategies for "Lost Space"[P]. ,2019.
  [48]Xinyue Zhang,Xin Zhang. Application of MOOCs in the construction of art and design courses[P]. ,2019.
  [49]Yun&apos,an Zhao. The Construction of Hidden Curriculum for Art Design Major in Colleges and Universities Taking Xijing University as an Example[P]. ,2019.
  [50]Wei Zhou,Min Huang. Research on Teaching and Application of Public Art Application of Public Art Design in Construction of Beautiful Rural Area[P]. ,2019.
Current Value 7931
Update Date 2019-09-27
