南京某学校4层图书馆毕业设计(计算书+图纸)[面积3088]
本图书馆建筑主体结构采用现浇钢筋混凝土框结构。要求共四层,总建筑面积为4000m2。遵循“安全,适用,经济,美观”的原则,结构布置合理,房间利用率比较高,适用性很强,同时又不失美观。主要功能有:阅览室,语音室,书库,采编、编目以及办公用房等。每个房间的门窗也都按照规范设计,符合规定要求,设计得合理,柱网布置需使结构受力合理,且应方便施工。
关键词:结构 楼盖 楼梯 框架
The main structure of the library construction using cast-in-place reinforced concrete box structure. Requested a total of four, with a total construction area of 4000m2. Follow the "security, application, economic, aesthetic" principle, the structure of a reasonable layout, room utilization is relatively high, the applicability of a strong, yet beautiful at the same time. The main features are: reading room, language lab, library, editing, cataloging, as well as office space and so on. Doors and windows in each room are designed in accordance with the norms, in line with the requirements, designed to be reasonable, net column layout so that the structure of the force to be reasonable, and should facilitate the construction.
Keywords: Frame Floor Staircase Framework
建筑面积:3088m2
建筑层数:4层
建筑高度:16.2m
计算书打印稿.pdf
QQ截图20151031144652.png QQ截图20151031144708.png QQ截图20151031144732.png QQ截图20151031144741.png
Current Value 13368
Update Date 2015-10-31
