该建筑是某学院办公楼,位于沈阳市,建筑面积为5444.60m2,层数五层,各层层高均为3.6m,总建筑高度为22.05m,结构设计合理使用年限50年,抗震设防烈度为7度,墙体材料为陶粒混凝土空心砌块。
本建筑坐北朝南,建筑平面为一字形,布局对称,布有普通办公室40间,高级办公室20间,一个中型会议室,男女卫生间分别布置楼梯两侧,大空间主要布置在南侧,小空间布置在北侧,合理布置,采光较好。
中间布置一部楼梯,端部一部电梯,楼梯采用板式楼梯,为封闭式楼梯,满足防火要求,玻璃幕墙,更加体现整体美观,大方。
结构类型为现浇钢筋混凝土框架结构,柱网布置合理,主梁,次梁合理搭配,满足结构受力要求,在框架结构计算时,采用PKPM软件计算。
关 键 词:办公楼;建筑设计;结构设计;框架结构;施工组织.
The building is a college building, located in Shenyang, the gross floor area for 5444.60m2, five-storey low-rise, high levels of 3.6m, total building height of 22.05m, well-designed structure of the service life of 50 years, seismic intensity 7, wall materials for the Ceramsite concrete hollow block. Construction of the ride south, construction is a flat-shaped, symmetrical layout, the General Office of the building there are 40, the Office of the High 20, a medium-sized conference rooms, bathrooms for men and women were arranged on both sides of the staircase, the space layout in the main on the south side of the small space On the north side of the arrangement, reasonable layout, better lighting. Layout in the middle of a staircase, an elevator, stairs plate using the stairs, closed the stairs to meet fire safety requirements of the glass curtain wall, as a whole reflects the more beautiful, generous. Structure for the type of cast-in-place reinforced concrete frame structure, the column set a reasonable network, the main beam, beam at a reasonable mix of force structure to meet the requirements in the framework of structural calculations, the use of computing software PKPM. Key words: office building; architectural design; structural design; frame; construction.
建筑面积:5444m2
建筑层数:5层
建筑高度:22.05m
学院设计说明书.pdf
(1.82 MB, 下载次数: 1)
