• 公众号
    微信扫码快速关注
  • 优秀毕业设计精选
    分享网站给同学朋友一起完成毕业设计
    毕业个人简历下载
    土木毕设网
    某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140]
    资料分类:土木工程设计资料 - 建筑结构毕业设计范文参考资料 | 发布形式:资料共享 | 更新时间:2015-11-24 显示全部楼层
    内 容 摘 要
    在满足使用功能的前提下,根据设计资料、水文地质资料和抗震等有关资料,本设计结构采用现浇钢筋混凝土框架结构形式,采用简单使用的〞一字形〞体型。层数为5层,总建筑面积约5200㎡。本册说明书是结构设计部分的计算说明书,主要设计计算的内容有:
    1.        结构布置及选型;
    2.        重力荷载计算;
    3.        结构构件刚度计算;
    4.        横向水平地震作用计算,根据顶点位移法和反弯点法计算。
    5.        竖向荷载作用下的框架结构内力计算。对⑨轴线一榀框架进行荷载受力分析,利用二次分配法计算梁、柱端的弯矩。最后进行内力组合,依据组合值进行配筋;
    6.        对节点核心区的验算;
    7.        楼梯的计算及对梯段、平台梁和平台板的配筋;
    8.        基础的设计包括独立基础和联合基础的设计及配筋;
    9.        论文是关于混凝土砌块在建筑上的发展,进行英语翻译;
    10.        PKPM计算书部分。
    关键词:框架结构  地震力  地震作用  基本组合  截面设计  PKPM计算
    《Hydrological Bureau of Inner Mongolia office building project》
    Meet in the use of the premise, according to the design of the data, hydrological and geological seismic data and other relevant information. The design structure using cast-in-place reinforced concrete frame structure, a simple use of the "chisel" shape. Floors of a five-storey, with a total construction area of about 5200 ㎡. List of the brochure is part of the structural design manual calculation,the main design elements are :
    1. Selection of the structure and layout;
    2. Gravity load calculation;
    3. Structural component stiffness calculation;
    4. Seismic horizontal level,according to the apex displacement and inflection point method.
    5. Vertical load under the framework of internal force structure calculation. ⑨ axis right framework for a load load static and secondary distribution method beams and columns side of the moment. Internal forces for the final composition,based on portfolio values reinforcement;
    6. On the core nodes checking;
    7. Calculation of stairs and escalators of the podium, beams and plates reinforced platform;
    8. Based designs including an independent foundation and the basis for the joint design and reinforcement;
    9. Thesis was on the concrete block building in the development, English translation;
    10.PKPM part of computing
    Keywords: Frame Structure    Earthquake Force    Earthquakes
                 Basic composition     Section design
                 PKPM calculation
    建筑面积:5140m2
    建筑层数:5层
    建筑高度:18.9m
    文件内容:计算书+图纸+施工组织设计+进度图+布置图
    建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](1) 建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](2) 建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](3) 建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](4)
    建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](5) 建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](6)
    建筑结构毕业设计-某地5层框架办公楼建筑结构设计(计算书+图纸+施组)[面积5140](7)
    在线内容试读展示已结束,下载资料使用学习更方便
    全部评论 已有7条评论 发表评论
    六块六c 2015-11-25 11:31
    支持,内容不错,哈哈哈
    资料为会员分享仅供学习交流,如有侵权请通知删除
    在线学习土木工程毕业设计做法
    热门分类
    最新资料
