本论文主要讲述了小型旅游宾馆的设计过程。本宾馆属于建筑中的公共建筑,我在设计计算中参考了较多的相关书目,并且严格按照建筑设计规范来完成的。建筑设计中运用了新颖可行的设计方法,满足了建筑功能要求。结构计算中运用了最新的设计规范和合理的计算方法,具有良好的经济效果。综合以上两项,实现了用最少的钱,建最好的房子的目的。
本设计主要分为两大部分:第一部分为建筑设计。建筑设计是在总体规划的前提下,根据任务书的要求,综合考虑基地环境,使用功能,结构施工,材料设备,建筑设计及建筑艺术问题,解决建筑物的使用功能和空间的安排。依据建筑物的概念,建筑方针的原则,完成了宾馆设计以下几方面的设计:建筑总平面设计,建筑布局,基本单元设计,公共部分设计,空间组合设计,屋面设计,建筑立面设计及建筑防火设计等等。
第二部分为结构设计。结构设计由框架设计,楼梯设计,板设计和基础设计等组成。该建筑的抗震设防烈度为7度,抗震等级为二级,考虑水平地震作用对横向框架的影响。竖向荷载作用下,横向框架内力计算采用弯矩分配法,而内力组合比较了竖向荷载组合和竖向荷载与地震力组合时对框架梁,柱产生的不利影响,取两者中较大值对框架梁,柱进行截面设计。
关键词:建筑设计 建筑规范 内力组合;
This thesis told the design processes of some hotel mainly. This belong to public buildings of civil engerning building, in design of calculating consulting more relevant booklists, and finished according to the design specification of the building strictly. Have used the novel and feasible design method in the architectural design, has met the function request of the building . The structure has used the latest design specification and rational computing technology while calculating, have good economic results. Synthesize the above two items, has realized using the the least money, the purpose to build best house.
This design is divided into two major parts mainly: The first part is the architectural design。The architectural design is on the premise of master plan, according to the request of task book, considering the base environment synthetically, the function of use, the structure constructs, material equipment, architectural design and artistic question of the building , solve the function of use of the building and arrangement in the space. Whether according to concept design of building, principle policy ofbuilding,the design should finish the following aspects. The total planar design of the building , the overall arrangement of the building , the elementary cell is designed, the public part is designed, the space is made up and designed, the roofing is designed, the elevation design of the building and building fire prevention and design etc..
The second part is structural design.Structural design is consisted by design of frame, stair design, board design with the foundation designing etc. making up. Should build provide fortification against earthquakes earthquake intensity 7 , antidetonation grade for being tertiary , consider horizontal earthquake function impact on horizontal frame. Vertical to load function, horizontal frame internal force calculate and adopt the curved square to assign France, and internal force make up vertical to is it make up and not vertical to load with earthquake strength setting a roof beam in place to frame when making up to load, adverse effect that post produce, fetch the two great value set a roof beam in place to frame, post design the section.
Key words: Architectural design; Norm of the building; Internal force association.
建筑面积:4600m2
建筑层数:6层
建筑高度:25.15m
计算书.pdf
(3.38 MB, 下载次数: 0, 售价: 1 积分)
