某消防3层办公楼结构设计(计算书+图纸)[面积3000]
该工程为四层框架结构体系,整个建筑建筑面积约3000m2,建筑物平面为L形。走廊宽度1.8m,标准层高3.6m,室内外高差0.45m,其它轴网尺寸构件尺寸等详见平面简图。建筑使用年限为设计使用年限50年。
主要承重结构方案: 本工程采用全现浇钢筋混凝土框架结构,即全部竖向荷载和水平荷载均由框架承担的结构体系。竖向荷载作用下采用分层法、叠代法计算其内力,水平荷载作用下采用反弯点法、D值法计算其内力;现浇楼板,按弹、塑性理论分析方法进行结构内力分析和计算,按照规范、规程,采用合理的配筋的方式。
框架结构便于这种综合型办公楼的布置,所以该设计优先选取的是框架结构。
关键字:框架结构,综合办公楼
The project is a four-story frame structure, the building construction area of about 3000m2, flat L-shaped building. Corridor width 1.8m, standard-storey 3.6m, interior height 0.45m, other grid sizes scantlings etc. See sketch plane. The useful life of the building design life of 50 years.
The main load-bearing structure of the program: This project uses the full-situ reinforced concrete frame structure, that is, all the vertical load and horizontal load borne by the frame architecture. Under vertical loads using a hierarchical method, iterative method to calculate the internal forces, under lateral loads using the inflection point method to calculate the internal forces D value method; casting slab, according to elastic and plastic theory analysis and structural analysis of internal forces calculated in accordance with the specifications and reinforcement using reasonable manner.
This integrated framework to facilitate the arrangement of buildings, so that the design is selected priority framework.
Keyword: Frame structure, office building
建筑面积:3000m2
建筑层数:3层
建筑高度:16.35m
建筑结构毕业设计-某消防3层办公楼结构设计(计算书+图纸)[面积3000](1) 消防大楼结构计算书.pdf (1.2 MB, 下载次数: 3)
建筑结构毕业设计-某消防3层办公楼结构设计(计算书+图纸)[面积3000](2)
建筑结构毕业设计-某消防3层办公楼结构设计(计算书+图纸)[面积3000](3)
Current Value 12002
Update Date 2015-11-02
