某地区6层商场写字综合楼毕业设计(计算书+图纸)[面积5220]
摘    要
本工程是内蒙古包头市钢铁大街北段,荣资商场2号工程楼, 为六层框架结构,一、二层为商场,三—六层为写字楼,总建筑面积5220㎡。建筑高度为23.7m,室内外高差450mm。建筑防火等级为二级,建筑耐火等级为二级,耐久年限为二级。设计内容主要分为:1.建筑设计部分,2.结构设计部分。建筑设计部分主要包括:建筑平面设计;建筑立面设计;建筑剖面设计;建筑细部设计。结构设计部分为:选择结构类型,进行结构布置;估算梁、板、柱界面尺寸及材料等级;荷载计算;楼梯的内力分析及配筋计算;框架梁、板、柱的内力分析及配筋计算;基础设计。设计部分结束进行图纸绘制,建筑部分主要完成首层平面图,标准层平面图,立面图,剖面图,及各种详图;结构部分主要完成一榀框架图,楼板配筋图,楼梯配筋图,基础平面布置图,剖面详图。
关键词:框架结构  建筑设计  结构设计  图纸绘制
This engineering is steel avenue in the head City of pack in Inner Mongolia north segment, glory property the market No.2 engineering building, is the 6 F frame structure, 1 and 2 F is market, 3-6 F is office building, total building area 5220 ㎡ .Building height is 23.7 m, indoor outside Gao Cha 450 mm.Building fire prevention the grade is second class, building fire-proof grade is second class, enduring time limit is second class.The design contents is main to is divided into:1.Building design part, 2.Structure design part.The building design part is main to include:Building flat surface design;The building sign noodles a design;Building section design;Building minute part design.Structure design part is:choice structure type, carry on structure decoration;Estimate beam, plank, the pillar interface size and material grade;The lotus carry a calculatio;Stairs of inside dint analysis and go together with a Jin calculation;Frame beam, plank, pillar of inside dint analysis and go together with a Jin calculation;Foundation design.Design part be over carry on diagram paper to draw, building part main completion the first plane chart, standard layer plane chart, sign noodles diagram, cross section, and various detailed diagram;The structure part is main completion one Mao frame diagram, the building plank go together with Jin diagram, the stairs go together with Jin diagram, the foundation flat surface arrange diagram, section detailed diagram.
Keyword: Frame structure  Building design  Structure design  The diagram paper draw
建筑面积:5220m2
建筑层数:6层
建筑高度:23.7m
毕业设计计算书.pdf
QQ截图20151204121554.png QQ截图20151204121609.png QQ截图20151204121622.png QQ截图20151204121543.png
Current Value 11855
Update Date 2015-12-04
