中文摘要
本文详细说明了工程的建筑设计和结构设计的过程。建筑设计部分主要依据任务书基本要求进行平面、立面、剖面设计及柱网布置,并绘制建筑方案图。结构设计部分,通过PKPM软件建立多层框架计算模型结合SATWE模块计算结构内力在保证安全的前提下,对初步选定的构件进行优化,利用SATWE得到的标准值进行内力组合,并对电算得到的内力结果进行手算校核。对楼板、檩条、次梁、节点及基础手动设计。利用天正、AutoCAD等软件进行施工图的绘制。
关键词 钢框架、PKPM软件、荷载组合、压型钢板非组合楼盖、节点、檩条、基础
In this paper, the process of architectural & structural design is discussed in details. In the part of architectural design, plane & section plane design and layout of column grid are completed according to the assign-
ment desires, and the architectural plans are drawn. In the part of structural design, multi-storey frame model is set up using the software of PKPM, and then the process of computing the internal force of structural is done in the SATWE module. Combination of load is done by hand using the characteristic value from SATWE. In order to ensure the safety, improving the member is required. It is necessary that the results of internal force by PKPM are checked by hand. Besides, floor slab, purlin, secondary bean, joint, and foundation are designed by hand. Shop drawings are finished through TArch6 and AutoCAD.
Key words: steel frame, PKPM software, combination of load, steel deck reinforced incomposite slab, joint, purlin, Foundation
建筑面积:5147m2
建筑层数:4层
建筑高度:15.29m
毕业设计正文.pdf
(2.37 MB, 下载次数: 1)
