课设基本摘要
灌溉供水泵站应用于将低处河流或渠道中的水提到高处,对农田进行灌溉的泵站。泵站的选址及规模应根据水文地质条件,气象,取水是否方便,当地经济发展,灌区的标准等来确定,根据灌区不同,一般会有一级泵站提水和多级泵站提水的划分,本次设计将泵站建设在水源处,采用一级提水方式将水提到灌区高位水池中去,本次从引水渠道、前池、进水池、进水管道、泵房、出水管道、出水池,以及附属设备做了系统设计,对配件本次不做出具体说明,应根据时市场规格参考价格、性能、使用寿命进行选配。本次设计主要针对泵房以及进出水建筑物,因此对部分设施的设计没有明确给出,同时,对泵站也应进行科学合理的管理,本文简单给出部分泵站安全运行管理措施,可供参考。
关键词:泵房 进出水池 进出水管道 水泵 阀门
Irrigation water supply pump station used in low to high, the water in the river or channel mentioned,The farmland irrigation pumping station.The pumping station's location and size should be according to the hydrogeological conditions, weather, whether it's a good water, local economic development, to determine the standard of the irrigation area, According to different irrigation area, the general level of pumping station carry water and the division of multistage pumping stations carry water, This design, construction of pumping station in water source place,The primary water way will be referred to the pool of water,From the water diversion channels, the former pool, into the pool, water pipe, pump room, water pipe, a pool, and accessory equipment for the system design,For accessories,don't make specific instructions, should be by the market specification, the reference price, performance and service life,This design mainly aimed at the pump room and water in and out of the building,So the design of part of the facilities is not clearly given,At the same time, the pump station also should carry on the scientific and reasonable management,This paper simply presents part of the safe operation of the pumping station management measures, for reference。
Keywords:The pump room in and out of pool in and out of the water pipe the water pump the valve
泵站位于黄河中游黄土高原地区的灌区内,从灌区旁边的河流取水进行农田灌溉,河流百年一遇的最高水位38.0m,最低水位33.0m,正常水位35.0m,气候特点是冬季干旱少雨,秋夏多暴雨,春秋有霜降,冬季降雪。全市年平均气温11.1℃,最高气温34℃,最低气温-4.9℃,最大冻土深度1.35m。该灌区最大用量水近期10830m3/h,远期13750m3/h。灌区高位水池设计水位51.0m,水池距离水源2500m。
针对以上资料,在距离水源不远处修建一坐泵站,本次规划从引渠开始,水流依次经过前池、进水池、进水管道、水泵、出水管道、直至灌区高位水池,还需要根据情况配备一系列附属设备,泵房前有拦污珊、滤网、喇叭口、导水锥,泵房内进水管道附件包括吸水管,穿墙管、波纹伸缩节、检修阀,偏心异径管,水泵机组,出水管道包括渐放接管、逆止阀、截流阀、穿墙管、T型叉管等设施,泵房后是出水压力管道,直至出水池。
本次设计的内容主要为以下几个方面:
泵房
泵房类型确定为固定式干室型泵房,泵房的尺寸,包括长度、跨度、高度的计算,其中泵房长度取决于所选型号水泵机组的长度、机组与墙壁的距离(按照泵站设计规范确定)、检修间的长度(依据规范确定)三者的和;泵房的跨度取决于进水接管的长度、检修阀的长度、偏心异径管的长度、机组的宽度、渐放接管的长度、逆止阀长度、截流阀长度、短管长度以及定位轴线到泵房墙内侧的距离之和;泵房高度是指泵房地面高程到屋面大梁 的距离,主要取决于机组最高设备到底部的距离,车厢高度,起吊设备相关高度及安全高度之和。具体计算过程见本文第七章内容,最后加之对施工工艺的考虑,对泵房计算出的尺寸做一定调整,本次工程泵房尺寸设计为30m×18m×8m。
进出水建筑物:
首先确定出泵房尺寸后,考虑进水池,本次设计进水池形式采用矩形正向进水池,其长度可由每台机组的长度,机组的台数以及最两端喇叭口中心线(本次设计喇叭口采用垂直布置)到侧墙的距离之和来确定;其宽度根据秒换水系数公式来确定,本次设计根据进水池容积是总流量的50倍来计算,考虑到施工方便,最终对进水池尺寸做了一定调整,进水池尺寸为24.5m×5.0m。
要想确定前池尺寸需要知道引渠末端底宽,故接下来进行引渠尺寸的计算。引渠的尺寸主要是断面尺寸和长度。其中断面采用梯形断面,选择好相关水力参数后,按照水力最佳断面的方法进行,最终确定引渠的底宽为1.5m,其流速满足不冲不淤流速要求,引渠长度取值12.0m,具体施工时可根据情况调整。
前池尺寸的确定,参照教材《水泵与水泵站(第二版)》(中国农业出版社,王福军主编,232页),对前池尺寸计算采用公式法,长度最终结果为32.0m,可设置前池翼墙,从而保证水流条件良好。
出水池的确定,本次工程设计出水池采用正向出流,多台水泵并管后的单根钢管中水流进入灌区高位水池,根据教材《水泵与水泵站(第二版)》(中国农业出版社,王福军主编,241页),采用水面漩滚法计算出水池长度,本次设计出水池尺寸为6.5m×5.0m。
进出水管道
进水管道采用钢管,直径为700mm,经校核满足泵站设计规范中进水管流速要求,进水管口处加喇叭管,本次设计喇叭口直径为900mm,进水管口至水泵进水口之间需要增加穿墙管、波纹式伸缩节、检修阀、偏心异径管,各部件规格和尺寸祥见本文第六章。其中,喇叭口采取垂直布置形式,原因是假如采用水平式布置,则水泵安装高程自然会降低,使得检修间地面与泵房地坪高度差值变大,为了使楼梯设计满足规范要求,必定要增加泵房跨度。
出水管道采用钢管,直径为600mm,经校核满足泵站设计规范中出水管流速要求,水泵出水口至出水池出口之间需要增加渐放接管、逆止阀、截流阀、穿墙管,还有将六根出水管并管的T型叉管,之后采用的压力管道为钢管材料,压力管道直径本次设计取值1400mm,满足规范要求,输送水至出水池。各阀门和部件规格尺寸已在本文第六章给出了具体说明。
水泵
根据水泵设计扬程选择泵型,本次设计从上海凯泉泵业和上海连成泵业电子样本中选择,考虑到泵房便于管理和维护,最终确定了泵型为KQSN600-M19/470的水泵,经校核,流量和扬程满足设计要求。五台运行,一台备用。在泵房内机组采取双列交错式布置,水泵主要技术参数详见本文第五章图2和表2.本次设计水泵允许吸水高度为2.05m,安装高程36.05m。动力机的选配根据电机功率确定,选择Y355M-6型号动力机。
其他附属设施
考虑到水流流态以及水泵吸水条件,本次设计可在前池与进水池交接处设置滤网,在进水池里、喇叭口下方设置导水锥,引导水流进入进水管,鉴于是农田灌溉引水,且本次对河流泥沙不做详细考虑,故可设置拦污珊,防止杂草等漂浮物进入水池,拥堵水管。
文件名:水利与土木工程泵站课程设计(设计书 图纸).rar
