本设计主要是编制投标文件,包括施工组织设计和投标报价等。
口闸工程位于长江口处,地基土质较差,地基处理较复杂,而且工程量大。工程采用双孔护镜门方案,单孔净宽 40 m,总净宽 80 m,底板体积大,砼浇筑强度较大,而且容易产生裂缝。闸门为半圆形的三铰拱结构,安装、运输困难。针对以上特点,在施工组织设计中,采取了一系列工艺技术措施,提出了切实可行的施工方案,先进合理的施工进度,紧凑协调的施工布置, 并且在质量安全保证、文明施工和环境保护等方面,提出一些先进的技术措施和管理措施。
投标报价部分主要是从工程实际出发,仔细计算施工过程中可能发生的各项费用,作为制定标价的基础,然后考虑风险等其他条件,制定出比较合理的报价。
在设计过程中既充分运用了所学知识,又广泛参考了设计施工方面的有关书籍。当然,这都是在规范规定内做的设计,体现了科学性、规范性。
关键词:施工组织设计,投标报价
This design mainly is draw up the sancha river-mouth floodgate engineering to bid document, include the construction organization design and bid to quote etc..
The sancha river-mouth floodgate engineering locates the sancha
river, the access to Yangtze River. The quality of foundation soil is worse, so the foundation stratum is the more complicated, and it has great quantity. The engineering adopt double bores, the clean breadth of single bore is 40 m, and the total clean breadth is 80 m, so the physical volume of scaleboard is big. The strength of pour concrete is big, and it creat crack easily. The gate is three hinge-arch structures of the hemicycle, installing and transporting is difficult. Aim at the above characteristics, in construction organize design, I adopted a series of craft and technique measure, put forward to the solid viable construction project, reasonable construction degree of progress of forerunner, the construction that tightly packed moderate arrange. Also I put forward the technique measure and the manage measure in the quantity safety, the civilized construction, and environmental protection etc..
The part of Bid quote is mainly from the engineering to set out physically, the careful calculation start construction process in various expenseses of the possible occurrence, be the foundation of draw up the marked price, then consider the risk and other condition, the offer that draw up to compare the reasonable.
In design process, I made use of the most of the knowledge we learned, and then consulted relevant book of the design construction extensively. Certainly, this is all the design that does in norm rule,body now science and norm.
Keyword:the sancha river-mouth floodgate, construction organize
designing, biding to quote
工程概况
外秦淮河三汊河口闸位于江苏省南京市秦淮河东支流三汊河口入长江处。上游距新三汊河大桥约300米,下游距河口约150米。
三汊河口闸的主要功能是非汛期关闸蓄水,抬高外秦淮河水位,解决枯水期外秦淮河水很低,甚至干涸的问题,同时形成亲水景观改善城市水环境和城市形象。汛期来临则打开闸门放水,不影响外秦淮河行洪;河口闸尽量兼顾旅游、景观功能,不考虑外秦淮河的航运功能。
三汊河口闸正常蓄水期的过流量为30m3/s;非汛期行洪流量为80 m3/s(关闸蓄水状态);汛期行洪流量为600 m3/s。本工程采用双孔护镜门方案,单孔净宽40m,总净宽80m。闸门为半圆形的三铰拱结构,闸门由卷扬式启闭机启闭,启闭机机房位于闸墩上的排架上。工程闸室采用整体坞式结构,在中墩处分缝。底板地基处理采用钻孔灌注桩。外秦淮河防洪工程为一等1级,三汊河口闸工程的等级为二等2级。本工程建筑物按地震烈度7度设防。闸址处防洪安全超高为2.0m(包括风浪爬高)。
自然条件
水文气象条件:
工程所处流域多年平均降水量1012毫米,由北向南递增,全年降水日数110~130天。最大年降水量2015.5毫米(1991年),最小年降水量为448.0毫米(1978年),极值比达4.5。汛期在5~9月,平均降水量为652.0毫米,占年平均降水量的63%。全年常有三个明显的多雨期,4~5月份上旬春雨连绵,称为“桃花雨”;9月份常有台风影响,多秋雨。流域年平均蒸发量为1000毫米,6~9月份总蒸发量占年蒸发量的一半左右,从蒸发量与降水量的对比表明,秦淮河流域处于湿润与干旱的过度地区。根据武定门闸水文站1960年设站后的7年实测资料分析,秦淮河流域平均年径流量为6.59亿立方米,相应径流深272毫米,最大年径流量为15.2亿立方米(1956年),最小年径流量为0.281亿立方米(1978年),极值比高达54。
流域属***带湿润、半湿润季风气候区。多年平均气温15.40C,最高气温43.00C(1934年7月13日),最低气温-14.00C(1955年1月6日)。全年日照时数为2148.3小时,日照率49%。一年之中温差较大,四季分明,降水比较丰沛。
部分内容展示
