资料简介: 摘 要
本工程为综合楼,工程的占地面积为1998.72㎡,总的建筑面积为8058.88㎡,建筑物总长度为60.60m,总宽度为61.20m,建筑物总高度为22.100m。结构类型为钢筋混凝土框架结构。
本计算书主要包括建筑结构设计说明、钢筋混凝土框架建筑设计、结构设计、深基础施工组织设计和工程造价计算四部分。结构设计围绕单项工程展开,施工组织设计和预算及清单计价是围绕基础工程展开的,重点是后三部分。在结构设计时,采用D值法和弯矩二次分配法分别计算横向水平地震作用下框架内力和竖向荷载作用下内力;施工组织设计包括施工方案选择、施工计划、施工平面图设计和技术组织措施。工程施工进度计划的表达是采用横道图方法。在进行造价计算时,施工图预算运用广联达软件进行了工程量定额计算,并编制了计算书,并编制了计算书。利用施工图预算结果,进行工程量清单计价的编制。
关键词:结构设计;施工组织设计;概预算;清单计价;
building of this project , the project covers an area of 1998.72 square meters , total construction area of ??8058.88 square meters , building a total length of 60.60m and a total width of 61.20m , the building is a total height of 22.100 m. The structure type is reinforced concrete frame structure.
This calculation include reinforced concrete frame construction design, structural design ,the construction organization design, and project cost calculation four parts. Structure design, individual project on the construction organization design, and budget is based on engineering, especially around the three parts. In structural design, use D value method and calculation method of secondary moment distribution respectively lateral seismic action .based framework and vertical load internal frame, The construction organization design including the construction scheme selection, construction planning, construction plan design and technical measures. Engineering construction schedule by a bar chart of expression . In the cost calculation, construction drawing budget by the quantity of enterprise, and the calculations .Using the results of construction drawing budget, the valuation.
Key words:Structure design;The construction organization design;Project budget;List valuation.共100页。
