框架结构住宅楼施工组织设计
总面积3020平方米的框架住宅楼,共有5层。底层层高3.900m,标准层3.000m。建筑±0.000m对应的黄海高程为3.550m。工程特点:施工现场场地已平整,场地宽敞,业主提供施工用水,施工交通运输较为便利。我们可以充分利用现有的施工场地,合理进行临时设施及机械设备的布置,以保证施工的正常有序进行。本工程采用的防水材料较多,、屋面、卫生间的防渗漏是保证本期工程质量的又一关键所在,必须采取有效的防水技术保障措施来预防这类质量问题的发生。工程量大、结构新颖。工期短、质量高。各工种、工序在施工过程中交叉配合,工序搭接必须注意科学管理,统一协调。
关键词:施工组织计划、施工方案、施工进度计划、工程报价
Construction organization design and quotation of residential building
The total area of 3020 square metres of frame residential buildings, a total of 5 layers. The bottom storey is 3.900m and the standard layer is 3.000m. The building elevation of the Yellow Sea + 0.000m corresponds to 3.550m. Features of the project: the site of the construction site has been leveled, the site is spacious, the owner provides construction water, and the construction of transportation is convenient. We can make full use of the existing construction site, reasonable temporary facilities and mechanical equipment layout, in order to ensure the normal and orderly construction. This project uses more waterproof materials, anti leakage, roofing, toilet is to ensure the engineering quality and a key, must take place to protect waterproof and effective technical measures to prevent this kind of quality problems. Large amount of engineering, novel structure. Short construction period, high quality. All types of work and process in the construction process of cross matching, process overlap, we must pay attention to scientific management, unified coordination.
Key words: construction organization plan, construction plan, construction schedule, project quotation
