某地区8层框架结构的商贸大厦毕业设计(计算书+图纸)[面积13000]
摘  要
本次毕业设计的任务是一幢八层框架结构的商贸大厦。该大厦位于郑州市东区CBD中心,集商场、超市、写字间于一体。主体为八层框架结构体系,建筑面积约为13000㎡,建筑高度为40.6m。此次毕业设计以设计任务要求和建筑施工规范为原则,综合考虑基地环境、使用功能、结合选型、施工、材料、设备建筑、经济指标及建筑技术等,使建筑与环境融为一体,以达到建筑与周围环境的完美结合。
本次设计包括绪论、框架结构设计、楼梯设计、楼板设计及基础设计五大部分。绪论主要包含工程概况、设计资料和设计内容三方面。
结构设计主要是在建筑初步设计的基础上确定建筑的结构为钢筋混凝土框架结构,然后进行结构布置,并初步估算、确定结构构件的尺寸,进行结构计算,包括荷载计算、水平地震作用下框架的侧移验算、水平地震作用下横向框架的内力分析、竖向荷载作用下横向框架的内力分析、内力组合、截面设计以及节点验算,楼梯、板和基础的设计与计算。最后并画出相应的建筑图和结构图。
The mission of this graduation design is an business trade mansion. That mansion locates in Zheng Zhou the east area CBD center, gathering market,supermarket and office in the integral whole.The corpus is eight layer frame systems, building area about 13000㎡,building height is 40.6m. This graduation design take designing mission to request and constructing norm as a principle, consider base environment,use function,combine to choose a type,start construction,material,equipments building, economic index sign and construct a technique etc. comprehensivly, make building to merge into an integral whole with environment to attain building and surroundings environment of perfect combine.
This graduation design include the preface,the frame design,the stairs design,the building plank design and foundation to design among them five greatly part of.The preface mainly includes the engineering general situation,the design data and the design contents three aspects.
The structure design assurance the structure of the building and the reinforced concrete frame structure, with the foundation of initial design, then carry on the first estimate,assurance the size of the structure, carry on the structure calculation, include a lotus to carry calculation,the level earthquake function descend a frame of the side move to check to calculate,the level earthquake function descend a horizontal frame of inside dint analysis,the carries a function to descend a horizontal frame toward the lotus of inside dint analysis,inside the dint combine,section design and node to check to calculate, the stairs,plank and the design and the calculation of foundation.
建筑面积:13000m2
建筑层数:8层
建筑高度:40.6m
计算书.pdf
QQ截图20151201124535.png QQ截图20151201124551.png QQ截图20151201124608.png QQ截图20151201124620.png QQ截图20151201124636.png QQ截图20151201124501.png
Current Value 11751
Update Date 2015-12-01
